Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Core dumped when executing sample named 'vector-add' with oneAPI
fisrt , I installed oneAPI Base toolkits (beta) successful ,step is :
  • run command : tar -zxvf l_BaseKit_b_2021.1.3.085_offline.tar.gz
  • edit file ' silent.cfg ' ,set the 'ACCEPT_EULA' to 'accept'
  • launch the installation with command : sudo ./install.sh --silent ./silent.cfg
second, I configure the CPU and FPGA system
  • run setvars.sh for enviroment with command : source /opt/intel/inteloneapi/setvars.sh
finally, I am ready to run sample
  • download the Code Samples from github: https://github.com/intel/BaseKit-code-samples ;
  • cd ~/BaseKit-code-samples-master/DPC++Compiler/vector-add
  • make clean
  • make all
  • make run   but not succeed ,the error information is : segmentation fault(core dumped)
please help me
thanks a lot
Tags (1)
Highlighted
Hi Rui,
Hi Rui,
We are working on this issue and will get back to you.
Kaleem
Highlighted
Hello Rui,
Hello Rui,
We executed the vector addition program from the samples and it worked fine without any segmentation fault.
 Share your environment details and any information which helps us in debugging the issue.
Sushma.
