Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
371 Discussions
DPC++ compilation error in the DPCT migrated code
Onswar
I am examining the DPCT migration using a simple "CUDA 10.2 Runtime" project template.
When compiling the migrated DPC++ codes, it occurs the following compilation error.
1>In file included from kernel.dp.cpp:3:
1>In file included from C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\2021.1-beta09\include\dpct/dpct.hpp:27:
1>C:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\2021.1-beta09\include\dpct/device.hpp(218,16): : error : no member named 'max_element' in namespace 'std'
1> std::max_element(sub_group_sizes.begin(), sub_group_sizes.end());
I think that it is same the previous post.
https://community.intel.com/t5/Intel-oneAPI-Base-Toolkit/dpct-dpct-hpp-device-hpp-requires-c-17-feature/td-p/1211562/jump-to/first-unread-message
I confirmed occurring the compilation error in my migrated code after change to the project property
[DPC++]->[Language]->[C++ Language Standard]
/std:c++14, /std:c++17, /std:c++20
 respectively.
error log is same above.
std::max_element is defined at <algorithm> header, but it is not included in <dpct/dpct.hpp>
I tried the following modification, so compilation was succeeded.
before
#include <CL/sycl.hpp>
#include <dpct/dpct.hpp>
after
#include <algorithm> /* INSERTED */
kernel.dp.cpp
It may be need #include <algorithm> in device.hpp, I think.
  • Windows10 pro / Visual Studio Community 2019 (Version 16.7.3)
  • Intel Celeron (Skylake)
  • GPU: Gen9
  • 27.20.100.8681 DCH
  • Intel® DPC++ Compatibility Tool – toolkit version: 2021.1-beta09, extension version 2021.1.0.16, Package ID: w_oneAPI_2021.1.662
  • Intel® oneAPI DPC++ Compiler – toolkit version: 2021.1-beta09, extension version 2021.1.0.16, Package ID: w_oneAPI_2021.1.2115
  • CUDA 10.2
On
AbhishekD_Intel
Hi On,
The link to the post that you have mentioned is related to the Linux environment and that error is due to c++11 and c++14 standards.
The error you are getting is related to Windows System, though by default the compiler uses c++17 it will show this error in some environments. We have already reported this error to the concerned team.
As of now for a workaround, you can add #include <algorithm> in device.hpp file, so that you can compile all of your migrated codes without getting such error.
Warm Regards,
Abhishek
AbhishekD_Intel
Hi On,
Warm Regards,
Abhishek
Onswar
Thanks, response.
To use the suggested workaround is no problem, I can advance my experiments.
On
AbhishekD_Intel
Hi On,
Thanks for the confirmation, please feel free to post a new thread if you have any other issues.
Warm Regards,
Abhishek
