1.想请教一下,dpc++的kernel可以有通信吗?比如说我想用FPGA通过tcp连接来接收数据,然后再直接在FPGA里处理后通过tcp发送出去,整个过程数据不流过CPU,oneapi可以实现吗?
2.想请教一下,dpc++的kernel部分里是只能做数值的计算和逻辑判断吗?比如可以调用自定义的函数吗
3.有用oneapi做fast协议解析这方面可参考的资料吗
Please note that this is an English only forum.
However, upon using the language translate tool, I see the below output in English.
1. I would like to ask, can the dpc++ kernel communicate? For example, I want to use FPGA to receive data through tcp connection, and then directly process it in FPGA and send it out through tcp. The whole process data does not flow through the CPU. Can oneapi be implemented?
2. I would like to ask, can you only do numerical calculations and logical judgments in the kernel part of dpc++? For example, can you call custom functions?
To 3. Can you use oneapi for fast protocol analysis?
Could you please confirm if this is your question?
Rahul
Any updates on this? Could you confirm your questions?
Rahul
I have not heard back from you, so I will go ahead and close this thread from my end. Feel free to post a new question if you require any further assistance from Intel.
--Rahul
