Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
390 Discussions
DPC++ not able to detect NVIDIA GPU installed
Tholath__Jackson
I installed Intel oneAPI toolkit over VisualStudio 2019. I displayed the devices present in my machine using the below code.
struct gpu_selector : public cl::sycl::device_selector
    int operator()(const cl::sycl::device& d) const override
        if (d.is_gpu())
            std::cout<< "gpu Available: "  << d.get_info<cl::sycl::info::device::name>() << "\n";
            return 1;
        else
            std::cout<< "cpu Available: "<< d.get_info<cl::sycl::info::device::name>()<< "\n";
            return -1;
I got the following output:
cpu Available: Intel(R) FPGA Emulation Device
cpu Available: Intel(R) Core(TM) i7-8850H CPU @ 2.60GHz
gpu Available: Intel(R) UHD Graphics 630
gpu Available: Intel(R) Gen9
cpu Available: SYCL host device
As you can see it does not include NVIDIA gpu present in my system
In my Device Manager, I can see that NVIDIA Quadro P2000 is installed.
Is it possible to use DPC++ to target NVIDIA GPU's? If so what is the procedure?
Jackson
AbhishekD_Intel
Hi Jackson,
Currently, Intel OneAPI is not supporting NVIDIA GPU.
Please let us know if you face any related issues.
Warm Regards,
Abhishek
Tholath__Jackson
Thank you for clarifying.
Jackson
AbhishekD_Intel
Hi Jackson,
Thank you for your confirmation, can we close this thread?
You can always post a new thread if you have any issues.
Warm Regards,
Abhishek.
Tholath__Jackson
Thanks. The thread can be closed
Jackson
AbhishekD_Intel
Thank you, Jackson.
We are closing this issue. Please connect with us if you face any problem while using the OneAPI-base-toolkit.
Stay Healthy Stay Safe!!
-Abhishek
