Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
DPCT Error on matching constructors to variables
I wonder the case I am seeing is a DPCT limitation as there is no issue with NVCC. Essentially, I see that DPCT is having issue with complex data types.  In below code snipped, I get an error described as below:
: error: no matching constructor for initialization of 'hpmc::hpmc_counters_t'
hpmc_counters_t result;
Any guidance as how to get this code through DPCT?
here is the code causing above error:
struct hpmc_counters_t
    unsigned long long int translate_accept_count;      //!< Count of accepted translation moves
    unsigned long long int translate_reject_count;      //!< Count of rejected translation moves
    unsigned long long int rotate_accept_count;         //!< Count of accepted rotation moves
    unsigned long long int rotate_reject_count;         //!< Count of rejected rotation moves
    unsigned long long int overlap_checks;              //!< Count of the number of overlap checks
    unsigned int overlap_err_count;                     //!< Count of the number of times overlap checks encounter errors
    //! Construct a zero set of counters
    hpmc_counters_t()
        translate_accept_count = 0;
        translate_reject_count = 0;
        rotate_accept_count = 0;
        rotate_reject_count = 0;
        overlap_checks = 0;
        overlap_err_count = 0;
    //! Get the translate acceptance
    /*! \returns The ratio of translation moves that are accepted, or 0 if there are no translation moves
    DEVICE double getTranslateAcceptance()
        if (translate_reject_count + translate_accept_count == 0)
            return 0.0;
        else
            return double(translate_accept_count) / double(translate_reject_count + translate_accept_count);
    //! Get the rotate acceptance
    /*! \returns The ratio of rotation moves that are accepted, or 0 if there are no rotation moves
    DEVICE double getRotateAcceptance()
        if (rotate_reject_count + rotate_accept_count == 0)
            return 0.0;
        else
            return double(rotate_accept_count) / double(rotate_reject_count + rotate_accept_count);
    //! Get the number of moves
    /*! \return The total number of moves
    DEVICE unsigned long long int getNMoves()
        return translate_accept_count + translate_reject_count + rotate_accept_count + rotate_reject_count;
//! Take the difference of two sets of counters
DEVICE inline hpmc_counters_t operator-(const hpmc_counters_t& aconst hpmc_counters_t& b)
    result.translate_accept_count = a.translate_accept_count - b.translate_accept_count;
    result.rotate_accept_count = a.rotate_accept_count - b.rotate_accept_count;
    result.translate_reject_count = a.translate_reject_count - b.translate_reject_count;
    result.rotate_reject_count = a.rotate_reject_count - b.rotate_reject_count;
    result.overlap_checks = a.overlap_checks - b.overlap_checks;
    result.overlap_err_count = a.overlap_err_count - b.overlap_err_count;
    return result;
Highlighted
Could you attach the complete source code of the files that you are trying to migrate?
I will try to reproduce this issue from my end and get back to you.
Rahul
Highlighted
It may not be an easy thing to do due to nested dependencies spreading through multiple libraries. I will try to isolate the issue. But one question: I read somewhere that DPCT is not supporting inline functions. Is that true? Because this is an in-line function here.
Highlighted
Yes, that would be helpful.
For inline functions, can you give it a try by providing this extra flag during DPCT migration: --extra-arg="-std=c++17"
Rahul
Highlighted
Just a quick reminder to attach a small reproducer for your issue.
Rahul
Highlighted
Hi Rahul,
this turned out not to be an easy task. There are more than 20,000 errors I had to navigate through to create a test case. I have tabled this and will come back to it later. you can unfollow this issue for now.
thanks
Farshad.
