I wonder the case I am seeing is a DPCT limitation as there is no issue with NVCC. Essentially, I see that DPCT is having issue with complex data types. In below code snipped, I get an error described as below:
: error: no matching constructor for initialization of 'hpmc::hpmc_counters_t'
hpmc_counters_t result;
Any guidance as how to get this code through DPCT?
here is the code causing above error:
Could you attach the complete source code of the files that you are trying to migrate?
I will try to reproduce this issue from my end and get back to you.
Rahul
Yes, that would be helpful.
For inline functions, can you give it a try by providing this extra flag during DPCT migration: --extra-arg="-std=c++17"
Rahul
Just a quick reminder to attach a small reproducer for your issue.
Rahul
Hi Rahul,
this turned out not to be an easy task. There are more than 20,000 errors I had to navigate through to create a test case. I have tabled this and will come back to it later. you can unfollow this issue for now.
thanks
Farshad.
As per your request, I'll go ahead and close this thread from my end. Post a new question once you have the reproducer ready.
Rahul
