Please give us more details regarding your use-case.
Regarding support of SIMD if the hardware supports then subgroup is the way to achieve SIMD, as subgroups map to SIMD hardware.
Warm Regards,
Abhishek
Thanks. I have found some documents to introduce the SIMD of oneAPI. But I still have some questions, could you please help to clarify, Thanks.
- Does oneAPI try to enable SIMD as possible since the SIMD width is 16 when I run the vtune to diagnose the GPU performance even I don't write any subgroup code?
- How to specify the SIMD width manually?
- What are the possible reasons to stop a higher SIMD width? the number of EU registers?
We are forwarding this issue to the Subject Matter Experts.
Thank you
A new Explicit SIMD Programming Extension for DPC++ is coming up which helps with manually setting the SIMD width.
Topic Options
