Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Failed to activate the "Environment Configurator for Intel oneAPI Toolkits" extension. The extension
仁义_许_
Following this guidance for Mac:
When I type Intel oneAPI: Initialize, 2 options pop up:
  • Initialize default environment variables
  • Initialize custom environment variables
Click on either of them, a window is popped up:
Failed to activate the "Environment Configurator for Intel oneAPI Toolkits" extension. The extension is only supported on Linux and Windows.
ArpanB_Intel
Xu, could you confirm that the installation of Intel® oneAPI Base Toolkit for macOS* was successful and you are facing this issue during the configuration stage?
We would like to know.
仁义_许_
when I Type Intel oneAPI: Initialize, 2 options pop up:
This means the extension Environment Configurator for Intel oneAPI Toolkits has been installed.
This is only I can confirm.
VarshaS_Intel
Could you please elaborate on how you are getting these options and where you are running these options?
Could you please let us know what are the steps/link you are following and getting the errors?
And also, could you provide us with the screenshot of the error you are facing?
Thanks & Regards,
Varsha
仁义_许_
MACOS 11.6.4
Visual Studio Code 1.68.0
 The installing and building step link:
Build and Run a Sample Project Using Visual Studio Code (intel.com)
The little c step:
  • Click on
    Intel oneAPI: Initialize environment variables
This means the Toolkit is installed successfully.
However, the error window then pops up:
VarshaS_Intel
This is a known issue. It will be fixed in the future releases of Intel oneAPI Base Toolkit and HPC Toolkit. Could you please let me know if we can go ahead and close this thread?
Thanks & Regards,
Varsha
仁义_许_
When will the new release be proposed?
VarshaS_Intel
At this point, we are unsure about the timelines of when the issue will be fixed. But you can always refer to the release notes so as to get an update about it. Please find the release notes Intel Base Toolkit Release Notes  and Intel HPC Toolkit Release Notes
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need additional information, please post a new question.
Thanks & Regards,
Varsha
