Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Flags support to control floating-point calculations when using OneAPI via DevCloud
clicia
Dear all,
We have faced a problem when using dpct (available on DevCloud) regarding the use of some flags. We are using the following flags to compile the cuda code: --ftz, --prec-div, and --fmad. I tried to find equivalent flags for dpc++ code, but without success.
Some C++ documentation indicates the possibility of using the -ftz, -prec-div, and -fma flags, however, we see the following error when trying to include it in the compilation:
dpcpp: error: unknown argument: '-ftz'
dpcpp: error: unknown argument: '-prec-div'
Are there any suggestions on finding these flags for dpc++ code using dpcpp? Support for these flags does exist on OneAPI via DevCloud?
Thank you all.
GouthamK_Intel
Hi Clicia,
Thanks for reaching out to us!
For --ftz flag please refer the below link for more information.
https://software.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/floating-point-operations/understanding-floating-point-operations/setting-the-ftz-and-daz-flags.html
Regarding other options, we are forwarding this thread to the Subject Matter Expert who will guide you with more information.
Have a Good day!
Thanks & Regards
Goutham
clicia
Hi, Goutham
Thanks for your help with the -ftz flag. It works now. But we are still struggling to set -prec-div:
Remembering that I am logged in devcloud environment where I did some tests: When I compile a c++ program with icc the flag works fine. When I try to compile a dp.cpp program with the dpcpp compiler, this error appears.
Any help from Subject Matter Expert will be welcome.
Thank you again.
IntelSupport
with the command "dpcpp --help", there is no option "--prec-div​", and i checked the document https://software.intel.com/content/www/us/en/develop/documentation/oneapi-dpcpp-cpp-compiler-dev-guide-and-reference/top/compiler-reference/floating-point-operations/understanding-ieee-floating-point-operations.html, there shows "This version of the compiler uses a close approximation to the IEEE Standard for Floating-Point Arithmetic, version IEEE 754-2008, unless otherwise stated."
I'm not sure if dpcpp support this option, and i will further confirm with compiler team.
IntelSupport
I use command "icx -qnextgen-diag" to show the ICC classic options that are not accepted by icx. I found that the option "-prec-div" is not available currenty, but we may support it in the future.
Subarnarek_G_Intel
Can you try using -freciprocal-math instead of -prec-div and see if it resolves your issue?
Subarnarek_G_Intel
Escalated this case to the Engineering! Still waiting for customer reply!
