Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
386 Discussions
GPU drivers: packages intel-media-va-driver-non-free and limfx1 not found
nesavi
I am attempting to get Intel oneAPI up and running on Ubuntu 18.04.4, but I am having some trouble installing the GPU drivers, as per this site https://software.intel.com/content/www/us/en/develop/topics/graphics-linux-drivers.html
My PCI ID is 8086:3ea9, and when I follow the instructions given on the site, i.e. executing
cat << EOF | sudo tee /etc/apt/sources.list.d/intel-graphics.list
deb [trusted=yes arch=amd64] https://repositories.intel.com/graphics/ubuntu bionic main
EOF
sudo apt-get update
and
sudo apt-get update
sudo apt-get install \
  intel-opencl \
  intel-media-va-driver-non-free libmfx
I receive the following error messages:
E: Unable to locate package intel-media-va-driver-non-free
and
E: Unable to locate package libmfx1
Does anyone know whether this even matters, and if so, how I can remedy the problem?
Thanks in advance.
Varsha_M_Intel
There was an error in the instructions published to the software.intel.com site (the media packages are not available for Ubuntu 18.04.) We're working to get the content on that site updated.
Please use the following for now-
https://dgpu-docs.intel.com/installation-guides/index.html
GouthamK_Intel
Thanks for reaching out to us!
Could you please let us know the oneAPI Base toolkit version which you are using?
Also, we observed that in the commands which you have attached in the query. It says
intel-opencl \
Whereas, the command which is provided in the below link is https://software.intel.com/content/www/us/en/develop/topics/graphics-linux-drivers.html
sudo apt-get update
intel-opencl \
intel-media-va-driver-non-free libmfx1
Could you please confirm whether you are following the exact same command or not? If not please try with libmfx1 let us know the outcome of it.
Also, please share the error logs, so that it will help us to debug more on the issue you are facing.
Thanks & Regards
Goutham
nesavi
Dear Goutham
Thank you very much for the taking the time to look into the issue I raised. The missing "1" is a copy+paste on my part, when I was writing my post. I apologize for the inconvenience on your part.
Since I posted the original post, I have reinstalled Ubuntu 18.04.4 and I install Intel oneAPI basekit 2021.1 Beta08 on it.
I have attached a log of the commands I executed in a terminal windows. At lines 76, 82 and 123 you will find the message I originally posted about.  Preceding the attempt to install those packages not found I executed the following to update my packages repositories:
lassen@lassen-NUC8i5BEHS:~$ cat << EOF | sudo tee /etc/apt/sources.list.d/intel-graphics.list
> EOF
and then
lassen@lassen-NUC8i5BEHS:~$ sudo apt-get update
Hit:1 http://dk.archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://dk.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:3 http://dk.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:4 https://apt.repos.intel.com/oneapi all InRelease
Get:5 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Ign:6 https://repositories.intel.com/graphics/ubuntu bionic InRelease
Get:7 https://repositories.intel.com/graphics/ubuntu bionic Release [2,678 B]
Ign:8 https://repositories.intel.com/graphics/ubuntu bionic Release.gpg
Get:9 https://repositories.intel.com/graphics/ubuntu bionic/main amd64 Packages [6,350 B]
Fetched 97.8 kB in 4s (26.7 kB/s)
Reading package lists... Done
Here are the message relating to packages not found:
lassen@lassen-NUC8i5BEHS:~$ sudo apt-get install \
> intel-opencl \
Building dependency tree
Reading state information... Done
and
lassen@lassen-NUC8i5BEHS:~$ sudo apt-get install intel-opencl intel-media-va-driver-non-free libmfx1
and
lassen@lassen-NUC8i5BEHS:~$ sudo apt-get install intel-media-va-driver-non-free libmfx1
I hope you find this useful.
Thanks in advance for looking into this.
Sincerely,
nesavi/Thomas
nesavi
Hi @GouthamK_Intel
Any chance that you guys have had the opportunity to look in to this issue?
nesavi
Varsha_M_Intel
Could you please try the instructions in the site below-
https://dgpu-docs.intel.com/installation-guides/ubuntu/ubuntu-bionic.html
Please let me know if it worked fo ryou.
Varsha_M_Intel
nesavi
Hi @Varsha_M_Intel
I will try your work-around and post my results here. Thanks for your response.
