I have installed one-api toolkit, but my computer is offline.So when I use visual stdio 2019, it always displays a window "The samples feed is empty".Also I cannot click "Browse Intel oneAPI Samples" in "Extentions" in Visual Stdio 2019. So how can I copy or build oneapi-samples in directory ".../AppData/Local/Intel/oneapi/samples" in an offline computer?
- Tags:
- i-sa
We have also tried browsing oneAPI samples in offline mode and observed a similar window.
Now click "ok" in the pop-up window and select the project that you want to create.
Please refer to the below screenshots where we have created a project in offline mode.
We can also create oneAPI sample in offline mode in oneAPI command prompt using the below command:
oneapi-cli
and follow the instructions as required in the GUI.
Please refer to the below screenshot where we have created a project in offline mode in command prompt.
Please refer to the below link for more details:
You can get the visual studio project file by extracting the tar file and then open the solution file using visual studio to build your project.
Thanks & Regards,
Noorjahan.
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
