Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
371 Discussions
How to use two tiles with oneapi 2022.1.0?
nahso
I am using ATS-P gpu, and I created a queue with gpu_selector, submitting a parallel_for task to the queue. The vtune profilling result shows only one tile(tile 0) was used, but I can not find APIs to explicitly use two tiles.
Therefore, how can I use two tiles?
VarshaS_Intel
We are working on your issue internally. We will get back to you soon.
Thanks & Regards,
Varsha
Alina_S_Intel
I have received your request. Thank you for raising it.
I hope the following link will give you sufficient information about using multi-tile Intel GPUs:
https://intel.github.io/llvm-docs/MultiTileCardWithLevelZero.html
There are comments on how you should change your code to support 2 tiles and in the very end there are links to examples.
Alina_S_Intel
We will no longer monitor this thread. Hope the link I provided earlier answers your question.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thanks!
