Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
426 Discussions
I want use heterogeneous Windows-Linux environment.
habbaya
Hello ~
I have two systems.
mpi01 (192.168.250.61) : Rocky 9.1
mpi-client01 (192.168.250.54) : Win10
ssh no password is ok.
[susol@mpi01 ~]$ I_MPI_HYDRA_DEBUG=1 I_MPI_HYDRA_BOOTSTRAP=ssh mpiexec.hydra -bootstrap ssh -hosts mpi-client01 hostname
[mpiexec@mpi01] Launch arguments: /usr/bin/ssh -q -x mpi-client01 /opt/intel/oneapi/mpi/latest/bin//hydra_bstrap_proxy
--upstream-host mpi01 --upstream-port 33447 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/latest/bin/
--tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1
/opt/intel/oneapi/mpi/latest/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[mpiexec@mpi01] check_exit_codes (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:117): unable to run bstrap_proxy on mpi-client01 (pid 16638, exit code 256)
[mpiexec@mpi01] poll_for_event (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:159): check exit codes error
[mpiexec@mpi01] HYD_dmx_poll_wait_for_proxy_event (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:212): poll for event error
[mpiexec@mpi01] HYD_bstrap_setup (../../../../../src/pm/i_hydra/libhydra/bstrap/src/intel/i_hydra_bstrap.c:1061): error waiting for event
[mpiexec@mpi01] HYD_print_bstrap_setup_error_message (../../../../../src/pm/i_hydra/mpiexec/intel/i_mpiexec.c:1027): error setting up the bootstrap proxies
[mpiexec@mpi01] Possible reasons:
[mpiexec@mpi01] 1. Host is unavailable. Please check that all hosts are available.
[mpiexec@mpi01] 2. Cannot launch hydra_bstrap_proxy or it crashed on one of the hosts. Make sure hydra_bstrap_proxy is available on all hosts and it has right permissions.
[mpiexec@mpi01] 3. Firewall refused connection. Check that enough ports are allowed in the firewall and specify them with the I_MPI_PORT_RANGE variable.
[mpiexec@mpi01] 4. Ssh bootstrap cannot launch processes on remote host. Make sure that passwordless ssh connection is established across compute hosts.
[mpiexec@mpi01] You may try using -bootstrap option to select alternative launcher.
This is Linux system's path.
But mpi-client01 system is Windows 10.
So, I want change "/opt/intel/oneapi/mpi/latest/bin//hydra_bstrap_proxy" path for windows 10.
How can I change ??
[susol@mpi01 ~]$ mpiexec -V
Intel(R) MPI Library for Linux* OS, Version 2021.8 Build 20221129 (id: 339ec755a1)
Copyright 2003-2022, Intel Corporation.
c:\>mpiexec -V
Intel(R) MPI Library for Windows* OS, Version 2021.8 Build 20221129
Thanks ~
ShivaniK_Intel
>>>How do I get a heterogeneous operating system (Windows-Linux) environment-supported version?
With Intel mpi 2018 U5 version -hostos is a valid flag, based on which we can assume that the cross-OS support also works, and this version is available for download on IRC.
With the support license you can download the older version from IRC - https://registrationcenter.intel.com/
>>>It's supported old version of OneAPI ?
Yes it's supported in the older version of Intel oneAPI
Thanks & Regards
Shivani
habbaya
Hello ~
This option Same also.
Never changed path.
Thanks ~~~
I_MPI_HYDRA_DEBUG=1 I_MPI_HYDRA_BOOTSTRAP=ssh mpiexec.hydra -bootstrap ssh -demux select -genv I_MPI_FABRICS shm:tcp -env I_MPI_ROOT c:\\'Program Files (x86)'\\Intel\\oneAPI\\mpi\\latest \
-env PATH c:\\'Program Files (x86)'\\Intel\\oneAPI\\mpi\\latest\\bin \
-host 192.168.250.54 -n 2 C:\\windows\system32\HOSTNAME.exe
[mpiexec@mpi01] Launch arguments: /usr/bin/ssh -q -x 192.168.250.54 /opt/intel/oneapi/mpi/latest/bin//hydra_bstrap_proxy --upstream-host mpi01 --upstream-port 41471 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/latest/bin/ --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 /opt/intel/oneapi/mpi/latest/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[mpiexec@mpi01] check_exit_codes (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:117): unable to run bstrap_proxy on 192.168.250.54 (pid 16715, exit code 256)
ShivaniK_Intel
Thanks for posting in the Intel forums.
To run a mixed Linux-Windows MPI job, do the following:
1. Make sure the Intel MPI Library is installed and operable, and the product versions match on all nodes.
2. On the Windows hosts, make sure the Hydra service is running:
> hydra_service -status
If the service is not running, use the -start option to start it
When running a mixed job, set the following options and environment variables:
1 -demux select
2 -genv I_MPI_FABRICS=shm:tcp
3 -host <hostname>
4 -hostos <os> for nodes operating on the other OS
5 -env I_MPI_ROOT and -env PATH – local environment variables for the specified host
6 (optional) -bootstrap ssh – specifies the remote node access mechanism. If the option is not specified, the Hydra service is used. If you specify ssh, make sure the SSH connectivity is established between the Linux and Windows nodes.
Also, please use the option "-hostos windows" as given below:
I_MPI_ROOT=<windows_installdir> -env PATH=<windows_installdir>\bin -hostos windows -host <windows-hostname> -n 2 hostname
Please follow the above steps & let us know if it resolves the issue. If you still face the same issue, then provide us the complete debug log along with the command you used.
Thanks & Regards
Shivani
habbaya
Hello ~
Thanks for reply.
A. Rocky 9.1
[susol@mpi01 ~]$ mpiexec -info
HYDRA build details:
Version: 2021.8
Release Date: 20221129 (id: 339ec755a1)
Process Manager: pmi
Bootstrap servers available: ssh slurm rsh ll sge pbs pbsdsh pdsh srun lsf blaunch qrsh fork
Resource management kernels available: slurm ll lsf sge pbs cobalt
B. Windows10
C:\Program Files (x86)\Intel\oneAPI>mpiexec -info
Version: 2021.8
Bootstrap servers available: service lsf blaunch
Resource management kernels available: hpc lsf
[susol@mpi01 ~]$ ssh 192.168.250.54 mpiexec -V
C:\Program Files (x86)\Intel\oneAPI>hydra_service -status
hydra service running on mpi-client01
C:\Program Files (x86)\Intel\oneAPI>mpiexec -validate
SUCCESS on host mpi-client01
### Result ###
[susol@mpi01 ~]$ I_MPI_HYDRA_DEBUG=1 I_MPI_HYDRA_BOOTSTRAP=ssh mpiexec.hydra -bootstrap ssh -demux select -genv I_MPI_FABRICS shm:tcp \
-env I_MPI_ROOT='"C:\Program Files (x86)"\\Intel\\oneAPI\\mpi\\latest' -env PATH='"C:\Program Files (x86)"\\Intel\\oneAPI\\mpi\\latest\\bin' -hostos windows -host mpi-client01 -n 2  'C:\\windows\\system32\\HOSTNAME.exe'
[mpiexec@mpi01] match_arg (../../../../../src/pm/i_hydra/libhydra/arg/hydra_arg.c:91): unrecognized argument hostos
[mpiexec@mpi01] Similar arguments:
[mpiexec@mpi01] host
[mpiexec@mpi01] hosts
[mpiexec@mpi01] h
[mpiexec@mpi01] hostlist
[mpiexec@mpi01] s
[mpiexec@mpi01] HYD_arg_parse_array (../../../../../src/pm/i_hydra/libhydra/arg/hydra_arg.c:128): argument matching returned error
[mpiexec@mpi01] mpiexec_get_parameters (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:1359): error parsing input array
[mpiexec@mpi01] main (../../../../../src/pm/i_hydra/mpiexec/mpiexec.c:1783): error parsing parameters
[susol@mpi01 ~]$
There is no option hostos.
And I tried exclude hostos option, I got a same result.
[susol@mpi01 ~]$ I_MPI_HYDRA_DEBUG=1 I_MPI_HYDRA_BOOTSTRAP=ssh mpiexec.hydra -bootstrap ssh -demux select -genv I_MPI_FABRICS shm:tcp -env I_MPI_ROOT='"C:\Program Files (x86)"\\Intel\\oneAPI\\mpi\\latest' -env PATH='"C:\Program Files (x86)"\\Intel\\oneAPI\\mpi\\latest\\bin' -host mpi-client01 -n 2 'C:\\windows\\system32\\HOSTNAME.exe'
[mpiexec@mpi01] Launch arguments: /usr/bin/ssh -q -x mpi-client01 /opt/intel/oneapi/mpi/2021.8.0//bin//hydra_bstrap_proxy --upstream-host mpi01 --upstream-port 35961 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/2021.8.0//bin/ --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 /opt/intel/oneapi/mpi/2021.8.0//bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[mpiexec@mpi01] check_exit_codes (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:117): unable to run bstrap_proxy on mpi-client01 (pid 18018, exit code 256)
If you need more information
please tell me.
Thank you so much.
ShivaniK_Intel
Sorry for the inconvenience. Officially, heterogeneous operating system (Windows-Linux) environment support is no longer available.
Thanks & Regards
Shivani
habbaya
Hello ~
Thanks for reply.
It's sounds very sad.
How do I get heterogeneous operating system (Windows-Linux) environment supported  version?
ShivaniK_Intel
We are working on it and will get back to you.
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks & Regards
Shivani
ShivaniK_Intel
As we did not hear back from you could you please let us know whether my previous post resolves your issue? If yes please accept it as a solution.
Thanks & Regards
Shivani
ShivaniK_Intel
Thanks for accepting our solution. If you need any additional, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards
Shivani
