I did the steps obtain a gpg key and add to the repository list. When I run `apt install intel-basekit`, I get a line that says `Ign` for the component named `intel-oneapi-vtune-eclipse-plugin-vtune`. `Ign` is supposed to mean that this component isn't necessary and can be ignored. However, further along in installation, I'm getting an error that says
Err:13 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-vtune-eclipse-plugin-vtune all 2022.2.0-173
404 Not Found [IP: xxx.xxx.xx.x xxx]
Fetched 3032 MB in 4min 28s (11.3 MB/s)
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-vtune-eclipse-plugin-vtune-2022.2.0-173_al... 404 Not Found [IP: xxx.xxx.xx.x xxx]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried to skip the vtune-eclipse component that's not found and I still can't build because another component named vtune requires vtune-eclipse and intel-basekit requires vtune.
system info:
- Installing within docker container
- Ubuntu 20.04
User internally confirmed the issue to be resolved.
Confirmation message:
Hi Arpan,
I don't know what got fixed between last week and now but I ran the following again and it now works.
>apt get update
Hi Winston, could you confirm the version of Linux you are using?
Also, as a possible workaround you can install individual tools as per your needs using their package names. To check the list of names of packages, visit> https://www.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-to...
Hi Arpan,
Thanks for the workaround. I see that the missing package exists in the list of available packages out there (intel-oneapi-vtune-eclipse-plugin-vtune) but when I try to install it, it gives me a "404 Not Found" error.
I attempted to install basekit with an apt command that ignores intel-oneapi-vtune-eclipse-plugin-vtune but it would say that it's required by intel-oneapi-vtune. I then tried installing basekit without both intel-oneapi-vtune-eclipse-plugin-vtune and intel-oneapi-vtune and I get an error saying that basekit requires intel-oneapi-vtune.
My docker container is running Ubuntu 20.04.4 LTS. The container is being run on macOS but I don't think that matters.
Here's the output when I run `apt install intel-basekit`
After this operation, 15.3 GB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-vtune-eclipse-plugin-vtune all 2022.2.0-173
Err:2 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-vtune amd64 2022.2.0-173
404 Not Found [IP: 104.119.89.7 443]
Err:1 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-vtune-eclipse-plugin-vtune all 2022.2.0-173
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-vtune-eclipse-plugin-vtune-2022.2.0-173_al... 404 Not Found [IP: 104.119.89.7 443]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-vtune-2022.2.0-173_amd64.deb 404 Not Found [IP: 104.119.89.7 443]
I tried installing a different version of basekit too (intel-basekit-2021.4.0) and got the same result.
Winston, thank you for sharing the update regarding your issue. Could you share the log files with us? On Linux, the default folder would be> opt/intel/oneAPI/logs
opt/intel doesn't exist. I'm assuming because it didn't make it to installing oneAPI.
Does it work when you try "apt install intel-basekit" it from your end? I tried it on two machines (docker container and native) here and it didn't work.
Winston, we have contacted you privately with some information. Please check your inbox for further updates.
Winston, we have again contacted you internally with some information. Please check your inbox for further updates.
Hi Arpan,
>apt get update
Winston, we thank you for sharing the confirmation with us. We are glad that the issue was resolved.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
