Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Integrating latest https://github.com/intel/llvm/releases/ into VS2019
ziglar
Hi, not sure if this is off topic but here goes ...
How do integrate my locally built clang toolchain from the latest daily https://github.com/intel/llvm/releases/ into VS2019?
GouthamK_Intel
Thanks for reaching out to us!
This forum is intended to support Intel oneAPI Products only. As we can see that you are using an open-source version of oneAPI, we request you to raise an issue in GitHub for faster response: https://github.com/intel/llvm/issues
If you intended to use Intel oneAPI Products, one place to download a free community version is the Intel oneAPI Base Toolkit and follow the installation guide to install the toolkit and required driver.
After installing the Intel oneAPI Base toolkit, you can refer to the below Get-Started guide for Linux.
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-bas...
Have a Good day!
Thanks & Regards
Goutham
GouthamK_Intel
Have a Good day!
Thanks & Regards
Goutham
GouthamK_Intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread.
If you require any additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only.
Have a Good day.
Thanks & Regards
Goutham
