Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
392 Discussions
Intel(R) Graphics Driver is not detected
nnain1
I have two GPUs Intel Graphic and Nvidia GPU.
My oneApi version is latest beta-05.
But when the device_selector code is run, it never detects GPUs.
class MyDeviceSelector : public cl::sycl::device_selector {
public:
    MyDeviceSelector() {}
    // This is the function which gives a "rating" to devices.
    virtual int operator()(const cl::sycl::device& device) const override {
        // The template parameter to device.get_info can be a variety of properties
        // defined by the SYCL spec's cl::sycl::info:: enum. Properties may have
        // different types. Here we query name which is a string.
        const std::string name = device.get_info<cl::sycl::info::device::name>();
        std::cout << "Trying device: " << name << "..." << std::endl;
        std::cout << "  Vendor: "
            << device.get_info<cl::sycl::info::device::vendor>() << std::endl;
        if (device.is_gpu()) return 500;
        if (device.is_accelerator()) return 400;
        if (device.is_cpu()) return 300;
        if (device.is_host()) return 100;
        return -1;
The ouput from running through the above code is as follow.
Why GPU is not detected?
Before beta-05 is updated, it was able to detect GPU using beta-03.
GouthamK_Intel
Hi Nyan,
As this is a duplicate thread, please refer to the below thread for more information.
https://software.intel.com/en-us/forums/intel-oneapi-base-toolkit/topic/851345
Goutham
