I just installed oneApi on my Ubuntu 20.04 machine. My gcc compiler successfully compiles this native on Ubuntu:
void mullo_epi8(__m256i a, __m256i b, __m256i& result)
// convert to 16bit and combine
__m256i tmp0 = _mm256_cvtepi8_epi16(((__m128i*)&a[0])[0]);
__m256i tmp1 = _mm256_cvtepi8_epi16(((__m128i*)&b[0])[0]);
__m256i tmp2 = _mm256_cvtepi8_epi16(((__m128i*)&a[0])[1]);
__m256i tmp3 = _mm256_cvtepi8_epi16(((__m128i*)&b[0])[1]);
// do the multiply
__m256i res1 = _mm256_mullo_epi16(tmp0, tmp1);
__m256i res2 = _mm256_mullo_epi16(tmp2, tmp3);
// convert back to 8bit
result = _mm256_permute4x64_epi64(
_mm256_packs_epi16(res1, res2),
0xD8 // 3,1,2,0
With the intel compiler I get errors:
__m256i tmp0 = _mm256_cvtepi8_epi16(((__m128i*)&(a.data()))[0]);
./turbo_coder.h:120:52: error: address of vector element requested
./turbo_coder.h:121:52: error: address of vector element requested
could you please try using &a instead of &a[0].
If the issue still persists, please let us know.
Thanks & regards
Noorjahan
Reminder:
Could you please confirm whether your issue is resolved. If yes, let us know if we can close this thread from our end.
Thanks & Regards
Noorjahan.
We are closing this thread assuming your issue has been resolved.
We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread.
Any further interaction in this thread will be considered community only..
Thanks & Regards
Noorjahan
