Community
cancel
Showing results for
Search instead for
Did you mean:
Issue with generation LLVM IR using oneApi
Jump to solution
Hi everyone.
I'm trying to split the compilation, and generate LLVM IR. But the compiler shows an error that IR output is not supported.
clang++ -fsycl -fsycl-unnamed-lambda -S -emit-llvm -ferror-limit=5 addTwoArrays.dp.cpp -std=c++17
error: IR output is not supported.
1 error generated.
Maybe someone has encountered this, or knows some other option to generate IR?
Thanks!
ShivaniK_Intel
I apologize for the delay.
Please follow the below steps to generate LLVM IR.
export IGC_DumpToCurrentDir=1
export IGC_DumpLLVMIR=1
dpcpp <code>.cpp
./a.out
Thanks&Regards
Shivani
ShivaniK_Intel
We are able to reproduce the error on our end. We are working on it and will get back to you soon.
Thanks & Regards
Shivani
ShivaniK_Intel
dpcpp <code>.cpp
./a.out
Thanks&Regards
Shivani
ShivaniK_Intel
Thanks for the confirmation! As your issue has been resolved, we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day!
Thanks & Regards
Shivani
