Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
374 Discussions
Issues compiling ShivaniK_Intel's hello_world.cpp.
Zippy_Pinhead
I am trying to build the hello_world.cpp ShivaniK_Intel suggested in this problem solution: community.intel.com/t5/Intel-oneAPI-Base-Toolkit/DPC-setup-question/m-p/1317438#M1823
I got past the fact that installing the intel-basekit did not include intel-oneapi-compiler-dpcpp-cpp-common as a prerequisite by installing it by hand. Now I am dealing with this issue:
toddb@zippy $ dpcpp hello_world.cpp
In file included from hello_world.cpp:1:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl.hpp:11:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/accessor.hpp:13:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/buffer.hpp:11:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/detail/buffer_impl.hpp:19:
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2336:48: error: 'T' does not refer to a value
using FieldT = decltype(__builtin_field_type(T, NumFieldsToCheck - 1));
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2333:20: note: declared here
template <typename T, unsigned NumFieldsToCheck>
13 errors generated.
To make this more complete, here is the program I am trying to compile:
#include <CL/sycl.hpp>
#include <iostream>
using namespace sycl;
const std::string secret {
"Ifmmp-!xpsme\"\012J(n!tpssz-!Ebwf/!"
"J(n!bgsbje!J!dbo(u!ep!uibu/!.!IBM\01"};
const auto sz = secret.size();
int main() {
queue Q;
char*result = malloc_shared<char>(sz, Q);
std::memcpy(result,secret.data(),sz);
Q.parallel_for(sz,[=](auto&i) {
result[i] -= 1;
}).wait();
std::cout << result << "\n";
return 0;
I do not know why ShivaniK_Intel chose such an unreadable example, but that is one of life's great mysteries. (smiley face)
Any help in getting this hello_world.cpp to compile is appreciated.
This is a fresh install of intel-basekit with the additional install mentioned above to fix the problem with the basekit prerequisites.
The install is on Ubuntu Linux Kernel version 18.04.6.
Thank you,
Zippy
ShivaniK_Intel
Could you please follow the steps in the below link and try re-installing the latest version of Intel oneAPI toolkits.
https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/install-using-package-managers/apt.html#apt
To check whether the installation is successful, first do run setvars.sh script as follows:
source <install-dir>/setvars.sh
Now, try checking any compiler version.
dpcpp --verion
Expected Output:
After successful installation, try running the hello_world.cpp program.
Compilation command: dpcpp hello_world.cpp -o hello_world
Execution command:./hello_world
Expected output:
Thanks & Regards
Shivani
ShivaniK_Intel
Could you please confirm whether you are able to compile and execute a sample simple-add program?
As the user from your referred thread is working on hello_world.cpp program from the Data-Parallel C++ book (https://link.springer.com/content/pdf/10.1007%2F978-1-4842-5574-2.pdf), so we have chosen the same source code.
Could you also confirm the version of dpcpp compiler you have been using?
Please refer to the attachment for the sample simple-add program.
Thanks & Regards
Shivani
Zippy_Pinhead
toddb@zippy $ dpcpp simple-add.cpp
In file included from simple-add.cpp:22:
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2337:36: error: use of undeclared identifier 'FieldT'
static_assert(is_device_copyable<FieldT>::value ||
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2338:56: error: use of undeclared identifier 'FieldT'
detail::IsDeprecatedDeviceCopyable<FieldT>::value,
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2349:46: error: 'T' does not refer to a value
using BaseT = decltype(__builtin_base_type(T, NumBasesToCheck - 1));
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2346:20: note: declared here
template <typename T, unsigned NumBasesToCheck>
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2350:36: error: use of undeclared identifier 'BaseT'
static_assert(is_device_copyable<BaseT>::value ||
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2351:56: error: use of undeclared identifier 'BaseT'
detail::IsDeprecatedDeviceCopyable<BaseT>::value,
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2370:64: error: 'FuncT' does not refer to a value
: CheckFieldsAreDeviceCopyable<FuncT, __builtin_num_fields(FuncT)>,
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2368:20: note: declared here
template <typename FuncT>
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/types.hpp:2371:62: error: 'FuncT' does not refer to a value
CheckBasesAreDeviceCopyable<FuncT, __builtin_num_bases(FuncT)> {};
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl.hpp:15:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/backend.hpp:23:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/kernel_bundle.hpp:13:
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/detail/kernel_desc.hpp:104:63: error: 'T' does not refer to a value
static constexpr auto n = __builtin_sycl_unique_stable_name(T);
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/detail/kernel_desc.hpp:102:20: note: declared here
template <typename T> struct KernelInfoImpl {
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/detail/kernel_desc.hpp:106:26: error: subscripted value is not an array, pointer, or vector
static KernelInfoData<n[I]...> impl(index_sequence<I...>) {
/opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/detail/kernel_desc.hpp:111:67: error: cannot initialize a parameter of type 'const char *' with an lvalue of type 'const auto'
using type = decltype(impl(make_index_sequence<__builtin_strlen(n)>{}));
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl.hpp:42:
In file included from /opt/intel/oneapi/compiler/latest/linux/include/sycl/CL/sycl/program.hpp:19:
/opt/intel/oneapi/compiler/2021.4.0/linux/include/sycl/ext/oneapi/experimental/spec_constant.hpp:54:59: error: 'ID' does not refer to a value
const char *TName = __builtin_sycl_unique_stable_name(ID);
/opt/intel/oneapi/compiler/2021.4.0/linux/include/sycl/ext/oneapi/experimental/spec_constant.hpp:34:32: note: declared here
template <typename T, typename ID = T> class spec_constant {
/opt/intel/oneapi/compiler/2021.4.0/linux/include/sycl/ext/oneapi/experimental/spec_constant.hpp:67:59: error: 'ID' does not refer to a value
13 errors generated
Above, you can see the same 13 errors when compiling simple_add.cpp.
Here is my version of dpcpp:
toddb@zippy $ dpcpp --version
Intel(R) oneAPI DPC++ Compiler 2021.1 (2020.8.0.0827)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/compilers_and_libraries_2020.4.304/linux/bin
Please let me know if there is anything else.
-Todd
p.s. Let me remind anyone reading that when I did the initial install, the CL (sycl) includes were not installed because of a broken dependency in intel-basekit. Here is what I have for intel-basekit and the item which failed to install properly:
toddb@zippy $ s apt install intel-basekit
Reading package lists... Done
Building dependency tree
Reading state information... Done
intel-basekit is already the newest version (2021.4.0-3422).
0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
Mon Oct 04 13:27:15 ~/Work/oneAPI/Hello_world
toddb@zippy $ s apt install intel-oneapi-compiler-dpcpp-cpp-common-2021.4.0
intel-oneapi-compiler-dpcpp-cpp-common-2021.4.0 is already the newest version (2021.4.0-3561).
Mon Oct 04 13:27:19 ~/Work/oneAPI/Hello_world
ShivaniK_Intel
dpcpp --verion
Expected Output:
Expected output:
Thanks & Regards
Shivani
Zippy_Pinhead
Shivani,
This worked! Thank you very much. I thought I had already "cycled the power" on the install once, but perhaps I missed something.
For anyone else trying this fix, I added this to your instructions:
After doing the autoremove, I checked to see if any components were still installed:
toddb@zippy $ s apt list --installed | grep intel-oneapi
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
intel-oneapi-common-licensing-2021.4.0/all,all,all,now 2021.4.0-327 all [installed,automatic]
intel-oneapi-common-vars/all,all,all,now 2021.4.0-327 all [installed,automatic]
intel-oneapi-compiler-cpp-eclipse-cfg/all,all,all,now 2021.4.0-3561 all [installed,automatic]
intel-oneapi-compiler-dpcpp-cpp-common-2021.4.0/all,all,all,now 2021.4.0-3561 all [installed]
intel-oneapi-compiler-dpcpp-eclipse-cfg/all,all,all,now 2021.4.0-3561 all [installed,automatic]
intel-oneapi-dpcpp-debugger/all,now 10.2.4-56 amd64 [installed]
intel-oneapi-dpcpp-debugger-10.2.4/all,now 10.2.4-56 amd64 [installed,automatic]
intel-oneapi-dpcpp-debugger-eclipse-cfg/all,all,all,now 10.2.4-56 all [installed,automatic]
intel-oneapi-runtime-dpcpp-cpp-common/all,all,all,now 2021.4.0-3561 all [installed]
I then was able to uninstall the rest by doing an "autoremove" on the licensing package, to which everything else appeared to be a dependent. You can see now there is nothing installed:
The output from the compiler version check and hello_world.cpp is the same as what you posted. Thank you once again for taking the time to help.
I will now install the debugger and a couple of other things and move forward!
-Zippy
ShivaniK_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will be no longer monitored by Intel.
Thanks & Regards
Shivani
