Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
LZ77 in the OneApi toolkit
IlanBar
I've just installed latest OneAPI toolkit
I'm looking for implementation example of LZ77 that uses AXV instructions
 where can I find this example in the toolkit
  Ilan Bar
ArpitaP_Intel
Hi Ilan,
First you need to open the samples in oneAPI toolkit, which you can get by following the below tutorial link
https://software.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-hpc-linux/top/run-a-sample-project-using-the-command-line.html
You can find the implementation of LZ77 algorithm by following the below path in Intel oneAPI samples.
Toolkit>oneAPI Direct Programming>DPC++ FPGA>Reference Designs>GZIP
Thanks!
ArpitaP_Intel
Hi Ilan,
Please let us know if your issue was resolved.
Thanks!
ArpitaP_Intel
Hi Ilan,
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks!
