Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
371 Discussions
MPI version of cpuinfo missing 'Processor Feature Flags'?
CFR
New Contributor II
Shouldn't there be feature flags for things like AVX512_VBMI2, AVX512_BITALG, GFNI, VAES, etc...?  Will this be updated for the next release of oneAPI?
Intel(R) processor family information utility, Version 2021.6 Build 20220227 (id: 28877f3f32)
Copyright (C) 2005-2022 Intel Corporation. All rights reserved.
===== Processor Feature Flags =====
______ __________ ________ _________ ________ _____ _____ ______ _____ _______ _________ _____ ______ ______
| SSE3 | PCLMULDQ | DTES64 | MONITOR | DS-CPL | VMX | SMX | EIST | TM2 | SSSE3 | CNXT-ID | FMA | CX16 | xTPR |
|______|__________|________|_________|________|_____|_____|______|_____|_______|_________|_____ ______|______|
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 0 | 1 | 1 | 1 |
|______|__________|________|_________|________|_____|_____|______|_____|_______|_________|_____|______|______|
______ ______ _____ ________ ________ ________ _______ ________ ______________ _____ _______ _________ _____ ______ ________
| PDCM | PCID | DCA | SSE4.1 | SSE4.2 | x2APIC | MOVBE | POPCNT | TSC-DEADLINE | AES | XSAVE | OSXSAVE | AVX | F16C | RDRAND |
|______|______|_____|________|________|________|_______|________|______________|_____|_______|_________|_____|______|________|
| 1 | 1 | 0 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
_____ _____ ____ _____ _____ _____ _____ _____ _____ ______ _____ ______ _____ _____ ______ _____ ________
| FPU | VME | DE | PSE | TSC | MSR | PAE | MCE | CX8 | APIC | SEP | MTRR | PGE | MCA | CMOV | PAT | PSE-36 |
|_____|_____|____|_____|_____|_____|_____|_____|_____|______|_____|______|_____|_____|______|_____|________|
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
_____ _______ ____ ______ _____ ______ _____ ______ ____ _____ ____ _____
| PSN | CLFSH | DS | ACPI | MMX | FXSR | SSE | SSE2 | SS | HTT | TM | PBE |
|_____|_______|____|______|_____|______|_____|______|____|_____|____|_____|
_________ ______ ______ ______ ______ ______ _________ _____ _____ _________ __________ ________ _____ ______
| FSGBASE | BMI1 | AVX2 | SMEP | BMI2 | ERMS | INVPCID | RTM | MPX | AVX512F | AVX512DQ | RDSEED | ADX | SMAP |
|_________|______|______|______|______|______|_________|_____|_____|_________|__________|________|_____|______|
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 0 | 0 | 1 | 1 | 1 | 1 | 1 |
____________ _________ ____________ ______ _____ __________ __________ __________ _____ __________ __________
| AVX512IFMA | PCOMMIT | CLFLUSHOPT | CLWB | IPT | AVX512PF | AVX512ER | AVX512CD | SHA | AVX512BW | AVX512VL |
|____________|_________|____________|______|_____|__________|__________|__________|_____|__________|__________|
| 1 | 0 | 1 | 1 | 1 | 0 | 0 | 1 | 1 | 1 | 1 |
_____________ ____________ _______________________________
| PREFETCHWT1 | AVX512VBMI | AVX512_4VNNIW | AVX512_4FMAPS |
|_____________|____________|_______________|_______________|
| 0 | 1 | 0 | 0 |
HemanthCH_Intel
We are working on your issue and will get back to you soon.
Thanks & Regards,
Hemanth
Viet_H_Intel
Can you please let us now which version of oneAPI you are referring to? and what command to execute to get that information?
CFR
New Contributor II
I'm thinking the next version of oneAPI release will be 2022.3 but maybe it's more a question of if/when we might expect to see cpuinfo fixed.
To run the program and get the output: 'cpuinfo -f'
Viet_H_Intel
Thanks, I've escalated this issue and will let you know when it's fixed.
