Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
Migration issues
Karangula
Hii,
After doing dpct for the application, '^ *module [^!]*' this special character has been listed in the current directory.
May I know what does that mean?
Thank you
RahulV_intel
Could you attach a screenshot for the same?
Also, provide your OS and oneAPI basetoolkit version details.
I've been using Ubuntu 18.04 along with oneAPI base-toolkit beta08 and I have not noticed such behavior.
Rahul
Karangula
Hii,
     Please refer the attachment.
I've been using ubuntu 18.04 and Intel oneAPI beta-09 version.
Karangula
RahulV_intel
Do you see the same behavior when you migrate any other application as well or is it specific to this particular application?
RahulV_intel
Any updates on this?
If a particular application is causing this issue, it would be really helpful if you could attach reproducer files for the same and also mention the steps that you have followed.
Rahul
RahulV_intel
I have not heard back on you. So, I will go ahead and close this thread from my end. Feel free to post a new question if your issue persists.
Karangula
Hii,
Its only particular to an application,not same with all the applications.
karangula.
