after installation of the oneAPI base toolkit I noticed that I cannot switch to the Intel C++ compiler if my C++ project configuration contains a solution platform other than x64 and win32.
This is the menue with x64 only
This is the menu with x64 and Linux - as you can see no Intel C++ Compiler to select.
Is there any way to fix this problem other than delete 'Linux' from the configuration platform?
Could you please specify your OS, oneAPI base toolkit, and Visual Studio versions?
Rahul
Loaded the oneAPI last week from the intel web - so I guess it is the latest version?
OS: Windows 10
Compiler: Intel 2021.1
VS: Microsoft Visual Studio Community 2019 Version 16.8.4
I've forwarded this query to the concerned team. They will get back to you.
Rahul
Hi Daniel_Droste, I installed VS2019 professional 16.8.4 and oneAPI gold version. But I couldn't set to Linux platform. And I learned from dev team, cross-platform compilation isn't supported now. I have several questions to ask,
1 . How to set to x64 and Linux platform?
2 . Did you configure the platform like this before with Intel compiler(IPSXE)?
1. I use VisualGDB to manage my linux version. I would be happy to switch my windows configuration to use the Intel compiler. But this is not possible since I have a Linux-configuration. The linux configuration uses gcc on a remote linux machine. I do not want to switch that one to use the intel compiler.
2. No, I just noticed that I can switch to Intel compiler on projects that uses 'default' MS configurations. But if you use a custom configuration you cannot switch to Intel since the menu is not available.
I configure the platform to x64 and Linux, and I can see Intel C++ Compiler,
But please note, even if can select the intel compiler, but it doesn't work. We can't support build the Linux binary on windows.
yes, I understand. I do not want to use Intel for a Linux configuration. I try to use it for the x64 configuration, but the Intel compiler it does NOT show up. Here is my configuration:
And here is the Intel Compiler Menue:
I want to use the Intel compiler for the x64 configuration, NOT the Linux config. But I see only "Use Visual C++" - although it is already VC++.
If I have a solution with just MS default configurations ("Win32", "X64") I can switch to Intel without any issues. This problem appears on my system only, if a project of a solutions contains a non-MS configuration.
There is a ARM platform on my environment, and I can also can select the intel compiler.
Yes, as I said. If you use MS-default configurations it works.
I create a new solution platform named "Linux", I also can select the Intel Compiler.
OK- seems to be an issue with VisualGDB.
Can you find what what the conditions are to see the menue-entries of Intel C++?
We can't reproduce your issue. But you can use the below method to select the intel compiler,
Go to Project->Properties->Configuration Properties->General, and change the Platform Tools.
