Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Notify progress from parallel_for
leonardo_forum
I would like to know if there is a way to report to the console the current progress (ex. a progress variable that's calculated inside the parallel_for) before that the whole parallel_for end.
I already tried the sycl::stream class but is printing everything togheter only when the whole computation is ended.
Thank you
SantoshY_Intel
>>" if there is a way to report to the console the current progress before that the whole parallel_for end."
Unfortunately, there is no way to report the progress until the kernel finishes execution.
You can use sycl::stream to print the values inside a kernel which will display after the execution of the kernel.
>>"I already tried the sycl::stream class but is printing everything together only when the whole computation is ended."
When strings are streamed to the object within a kernel, the contents are stored on an internal cl_mem object until the kernel finishes execution. The output is then passed to stdout when the stream object is destroyed by the runtime. Note that there is no guarantee on when the output will be displayed on stdout, only that it will be printed when the command group is executed.
Thanks & Regards,
Santosh
leonardo_forum
At this point the only way to have a kind of progress indication that I can think of is to use  get_wait_list() and wait for every element of the computation to increase a counter. Do you think this can works?
Thank you
SantoshY_Intel
>>"Do you think this can work?"
No, cl::sycl::event::get_wait_list() will return the list of events that this event waits for. Only direct dependencies are returned. Already completed events are not included in the returned vector.
Thanks & Regards,
Santosh
leonardo_forum
This is a pity and a big limitation.
With CUDA we can use a printf from the kernel and is executed almost immediately.
SantoshY_Intel
We can use gdb-oneapi debugger to debug the kernel code during its execution.
For more details please refer to the below link:
https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-debugging-dpcpp-linux/top.html
Thanks & Regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Is the solution provided helped? Please get back to us if you face any issues.
Thanks & Regards,
Santosh
SantoshY_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
