Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
417 Discussions
OneAPI Integration with Eclipse IDE on Windows
omer_navruz
During oneAPI Base Toolkit installation, only Visual Studio integration option is provided. I want to use oneAPI tools like vtune within my own (user-provided) Eclipse IDE.
As far as I know, the Linux installer provides Eclipse IDE integration. Is there a similar option in Windows?
SantoshY_Intel
>>"As far as I know, the Linux installer provides Eclipse IDE integration. Is there a similar option in Windows?"
Unfortunately, there is no such integration option available in windows. But, the Linux installer provides Eclipse IDE integration as mentioned in the link.
As per the below link, only the visual studio integration option is available in windows:
https://www.intel.com/content/www/us/en/develop/documentation/get-started-with-intel-oneapi-base-windows/top.html
Thanks & Regards,
Santosh
omer_navruz
Actually I thought this might be possible because I read the following content:
Integration of the Intel® System Debugger into Eclipse*
  1. Browse to <ISS_INSTALL_PATH>/debugger/xdb/ide_plugins/dropins./debugger/eclipse (or ISS_INSTALL_PATH>\debugger\xdb\ide_plugins\dropins\debugger\eclipse on Windows*), where the default for ISS_INSTALL_PATH is /opt/intel/system_studio_2017.y.xxx/ (or C:\Program Files (x86)\Intel\System Studio 2017.y.xxx on Windows*).
  2. Import directory "
There, it tells that there is a plugin for Eclipse integration. This is an old content, and I do not have that directory under "debugger" folder. Does this plugin still exist, or it is not supported anymore?
SantoshY_Intel
>>"Does this plugin still exist, or it is not supported anymore? "
The plugin mentioned in Integration of the Intel® System Debugger into Eclipse*  is very outdated, and it is no longer supported.
Thanks & regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Is your issue resolved? Please let us know if we can close this issue from our end.
Thanks & Regards,
Santosh
omer_navruz
Yes, it is resolved. As far as I see, Eclipse IDE integration is not supported anymore. Thanks for your support.
SantoshY_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
