Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
OneAPI module files missing various settings
Jan-Albert
I've installed Intel OneAPI 2021.4 in one of our HPC clusters (the base and HPC kit)
After install we ran the modulefiles-setup.sh to generate modulefiles.
However some of the generated modulefiles lack several settings, compared to sourcing with setvars.sh
Things like LIBRARY_PATH , LD_LIBRARY_PATH , PKG_CONFIG_PATH etc are not always set using the modulefile but are set when using setvars.sh
Most notable with the compiler package , causing issues with compilation
After adding this to the compiler modulefile things started working as expected :
prepend-path LIBRARY_PATH /cm/shared/apps/intel/oneapi/compiler/2021.4.0/linux/compiler/lib/intel64_lin:/cm/shared/apps/intel/oneapi/compiler/2021.4.0/linux/lib
prepend-path LD_LIBRARY_PATH /cm/shared/apps/intel/oneapi/compiler/2021.4.0/linux/compiler/lib/intel64_lin
prepend-path PKG_CONFIG_PATH /cm/shared/apps/intel/oneapi/compiler/2021.4.0/lib/pkgconfig
Is there a reason these settings were omitted or is this a bug ?
Jan-Albert
Good morning ,
Using Intel OneAPI Base 2022.1 I notice that when loading the modulefile compiler I get dependencies compiler-rt , tbb and oclfpga loaded automatically , where compiler-rt provides the LD_LIBRARY_PATH , LIBRARY_PATH etc
For reasons as of yet unknown the 2021 version doesn't load the dependency modules specified, will investigate this
For now issue solved
Soumya_M_Intel
Hi Jan-Albert,
Thanks for posting your concern on the forum. Since it is a post-installation query related to the Intel® oneAPI Base & HPC Toolkits, we are moving this topic to the 'Intel® oneAPI Base Toolkit' community for further assistance.
Have a nice day ahead.
Soumya
VidyalathaB_Intel
>>Most notable with the compiler package, causing issues with compilation
We've tried compiling a sample vector-add code by setting the environment, using modulefiles from the latest oneAPI 2022.1 and we don't see any issues during compilation and it is working fine.
Before proceeding with loading the required modules from oneAPI we assume that you have,
installed tclsh on to the Linux development system
installed the Environment Modules utility (i.e., module) onto the system
sourced the .../modules/init/sh (or equivalent) module init command
After that,
> cd <oneapi-root-folder>
  eg: cd /opt/intel/oneapi/ (default location of oneapi)
> ./modulefiles-setup.sh
> module use modulefiles
> module avail
> module load compiler
To test the loaded compiler, we tried compiling sample codes with icpc, icc & dpcpp compilers and did not get any issues during compilation and we could run the executables successfully.
The above steps are taken from the following link
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-programming-guide/top/oneapi-development-environment-setup/use-modulefiles-with-linux.html
We suggest you try with the latest oneAPI which is 2022.1 (as we see that you are using oneAPI 2021.4 version of toolkits) and please do let us know if you face any issues.
Vidya.
Jan-Albert
Good morning ,
VidyalathaB_Intel
Glad to know that your issue is resolved in the latest (2022.1) version and thanks for the confirmation.
As your issue is resolved we are closing this thread. Please post a new question if you need any additional information from Intel as this thread will no longer be monitored.
Have a Nice Day!
Vidya.
