- Tags:
- General Support
Dmitry,
Right. The exact source version for oneAPI release is not published. The merge/bug-fixing to LLVM is a continuous development progress. Any issues of DPCPP found, if not appear in the LLVM logs of next release candidate, please raise them.
Hi Savin,
We are working on it and will get back to you.
Kaleem
Savin,
The LLVM GitHub is the source code of intel compiler for the SYCL implementation - Intel oneAPI DPC++ Compiler which is part of Intel oneAPI Base Toolkit that you could install from the binary repositories as specified in your link https://software.intel.com/en-us/articles/oneapi-repo-instructions
The release notes of the OneAPI do not specify which revision of the repository was used to build the binaries. The question is: how can one find which revision of the source code repository is compatible with the binary release?
- Dmitry
Dmitry,
This link maybe helpful for you. https://github.com/intel/llvm/blob/sycl/sycl/ReleaseNotes.md
Dmitry,
You should read the link below:
https://github.com/OAI/OpenAPI-Specification/blob/master/versions/1.2.md
Developers team from
Hi Rajat, The link you provided seems to be relevant to a different standard. -Dmitry
