Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
358 Discussions
Option for assembling to flat binary format - Feature Request
cntk
Dear great minds of software engineering,
I've looked around for such feature at Intel documentation, but apparently I can't find it or it is not implemented (yet).
Therefore the following content in this post should be considered as a feature request for Intel compiler, or perhaps a new separate program shall be created as a part of the Base Toolkit.
An example of such feature can be found in other assemblers such as NASM, FASM and others.
For example with NASM
A very straightforward assembly code (saved in the file named input.asm
BITS 64  ; tells nasm to use 64-bit mode
mov eax, [gs:30h]
ret
 When assembled with the following command:
nasm -f bin -o output.bin input.asm
It produces an output file (named output.bin). By opening the file in Hex editor, we can see the following hex-bytes inside the file:
65 8B 04 25 30 00 00 00 C3
Great. This is the end result basically. We can see NASM achieves this by using file system to read/write and with BITS specified because by default it uses 16-bit mode.
For example with FASM
Currently FASM has some limitations (i.e. it is limited to 32-bit address space and it is also lacking macOS support out-of-box)... However I'd like to point out that it has a nice advantage, because FASM provides DLL version which can be used via FFI (foreign function interface) for interop from other programming languages. The DLL provides an exported function which can be invoked to assemble code to flat binary format in memory rather than using I/O like NASM; this of course gains performance boost.
Nonetheless, FASM can operate with files just fine, similarly to NASM:
use64  ; tells fasm to use 64-bit mode
xor eax, eax
mov eax, [gs:eax+30h]
ret
 To assemble (assuming the above snippet is saved in the file named input.asm
fasm input.asm output.bin
The above command will produce a file named output.bin with hex-bytes content:
 31 C0 65 67 8B 40 30 C3
Yet again, this is the end result basically. It is a little different compared to NASM, but works just the same...
I had mentioned there are also other approaches available, for example on Linux, it is not really trivial but can be achieved by using gcc & objdump commands.
Without further ado, I will wrap it up here. This feature is very useful in some areas such as embedding and AOT. For people who prefer Intel dialect, they would appreciate such a feature
Would Intel implement this feature?
Thanks in advance. Stay safe.
~ cntk
RahulV_intel
Could you please elaborate more on the new features that you are looking for?
I have used objdump on the DPC++ compiled executables. It worked fine for me.
Rahul
RahulV_intel
Hi @cntk,
Just a quick reminder to elaborate more on the additional features that you are looking for.
Rahul
RahulV_intel
I have not heard back from you, so I will go ahead and close this thread from my end. Feel free to post a new query if you require further assistance from Intel.
