First time posting here, so hopefully I'm posting in the correct location. I am currently in the process of benchmarking two pieces of software against each other, one that I have implemented and another that is the current state-of-the-art. Both of use standard BLAS routines such as dgemm. The performance of both softwares is heavily reliant upon the BLAS installation that they use. I need to make sure that I am making as fair a comparison as possible by using the same BLAS installation for both. Both utilize CMake to collect and link the necessary packages. I have built both linked to MKL. However, (using ldd and grepping for mkl) I noticed that one has linked to libmkl_rt.so, whilst the other has linked to libmkl_intel_lp64.so, libmkl_intel_thread.so and libmkl_core.so.
I originally made several unsucessful attempts to build each with the same shared objects. I have spent a while going through the documentation and cannot find anything about the exact differences in performance of these shared objects. Are there any significant performance differences between them? Do I need to worry about making an unfair comparison between the two softwares in the event that I attempt to publish the results?
Thanks in advance!
Thanks for reaching out to us, we will get back to you soon.
Rajesh.
Benjamin,
the performance could be the same on the same platform and the same inputs.
The issue is closing and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
