Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Problem after upgrading to 2024 version
pstickar_thl
Hello
I've just upgraded from oneApi 2023 to 2024, on Win10. The installation proceeded without any error messages or warnings of any kind.
When I try to open the VS 2022 solution, the projects do not load. When I click on "reload", I get the error message (attached):
The imported project file "C:\Program Files\Microsoft Visual Studio\2022\Professional\Msbuild\Microsoft\VC\v160\intel.cpp1a.platform.redirect.14.props" could not be loaded. Root element is missing. C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Intel.Cpp1A.Platform.Redirect.props.
Indeed, the file that cannot be loaded, does not exist.
I tried placing an empty file with that name, but it does not work.
Could you please help me to solve this problem?
Thank you in advance.
Kind regards,
Pablo
pstickar_thl
Note: The error message that I posted appears after my attempt with an empty file.
Without the empty file, that is right after the installation, I get:
The imported project file "C:\Program Files\Microsoft Visual Studio\2022\Professional\Msbuild\Microsoft\VC\v160\intel.cpp1a.platform.redirect.14.props" was not found. Confirm that the expression in the import declaration "C:\Program Files\Microsoft Visual Studio\2022\Professional\Msbuild\Microsoft\VC\v160\intel.cpp1a.platform.redirect.14.props" is correct, and that the file exists on disk. C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\MSBuild\Microsoft\VC\v160\Intel.Cpp1A.Platform.Redirect.props
Thanks for your attention to this issue.
Pablo
Devorah_H_Intel
Please provide the output from the About Microsoft Visual Studio page:
Inside Visual Studio click Help>About Microsoft Visual Studio then Copy Info and paste here.
pstickar_thl
Hello Debora,
thank you for the prompt answer.
You can find a sanpshot of the about-window in the attachment. The same information pasted as text:
Installed products:
Microsoft Visual Studio Professional 2022
Version 17.7.5
VisualStudio.17.Release/17.7.5+34202.233
Microsoft .NET Framework
Version 4.8.09037
Installed Version: Professional
Visual C++ 2022 00476-80000-00000-AA130
Microsoft Visual C++ 2022
ASP.NET and Web Tools 17.7.273.65229
Azure App Service Tools v3.0.0 17.7.273.65229
C# Tools 4.7.0-3.23469.2+a3b9f0c274649870015cfe508cacde8fdc15df55
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Cookiecutter 17.0.23189.3
Provides tools for finding, instantiating and customizing templates in cookiecutter format.
Intel® Advisor 2024 1.3.20
Intel® Advisor 2024, (Plugin Version 1.3.20), Copyright © 2009-2023 Intel Corporation. All rights reserved.
Intel® C++ Compiler 2024.0
Intel® C++ Compiler 2024.0, Copyright © 2002-2023 Intel Corporation. All rights reserved.
Intel® DPC++ Compatibility Tool 2024.0
Intel® DPC++ Compatibility Tool 2024.0, Copyright © 2019-2023 Intel Corporation. All rights reserved.
Intel® Libraries for oneAPI 2024.0
Intel® Libraries for oneAPI 2024.0, Copyright © 2019-2023 Intel Corporation. All rights reserved.
Intel® oneAPI DPC++ Compiler 2024.0
Intel® oneAPI DPC++ Compiler 2024.0, Copyright © 2019-2023 Intel Corporation. All rights reserved.
Intel® oneAPI Menu & Samples 10.10.392.9731
Intel® oneAPI Visual Studio Menu & Samples Extension
Linux Core Dump Debugging 1.0.9.34202
Enables debugging of Linux core dumps.
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
NuGet Package Manager 6.7.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
Python - Profiling support 17.0.23189.3
Profiling support for Python projects.
Python with Pylance 17.0.23189.3
Provides IntelliSense, projects, templates, debugging, interactive windows, and other support for Python developers.
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
TypeScript Tools 17.0.20829.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 4.7.0-3.23469.2+a3b9f0c274649870015cfe508cacde8fdc15df55
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual C++ for Linux Development 1.0.9.34202
Visual F# Tools 17.7.0-beta.23314.10+e612cf93b989503c89e3a5830090062b7ab5e143
Microsoft Visual F# Tools
Visual Studio IntelliCode 2.2
AI-assisted development for Visual Studio.
Just in case it plays a role, I mention that the OS is Windows 10 Enterprise, version 10.0.19045 build 19045, and that the CPU is an Intel Xeon e3-1220 v5. The projects I want lo (re)load are C++ projects, which compiled and executed with the 2023 version.
Kind regards,
Pablo
Devorah_H_Intel
Can you try to Repair option of the oneAPI Toolkit installer and see if that fixes the issue. You are able to create a new project correct? The issue is with opening existing solution only?
Another suggestion is to Repair VS and then reinstall the Intel Base toolkit.
pstickar_thl
Hello Deborah,
unfortunately that did not work.
I can create a new project, yes, and afterwards select a non-Microsoft compiler in the properties.
Because of deadlines, I have no option but return to the 2023 version.
Next time I try, I will do different: first I'll switch all VS projects to use the Microsoft compiler, then the installation/update, and finally edit all projects again to use the Intel compiler.
Of course it is in our interest here to keep up with newest development tools, but I think that the next try will not happen before two weeks. At that point this thread will be closed. If I run into new problems, I'll post a new question.
Thank you for your help.
Kind regards,
Pablo
