Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
Problem(s) with svml
jwong545
I'm having some problems with an undefined variable (variable is "__svml_log16"). I have attached one picture that shows undefined variable. I do not have "svml" in a file .cpp.
Thank you.
GouthamK_Intel
Thanks for reaching out to us!
Could you please provide steps to reproduce and source code for which you are getting this error?
Also, let us know the environment details:
OS Version
oneAPI toolkit version
If you are working on Linux Machine please provide the output of clinfo command.
Thanks & Regards
Goutham
jwong545
Steps to Reproduce:
1. command 'make' to call Makefile
2. run 'run.sh' (bash ./build/bin/rogue-5-oneAPI -g 10 -i ./build/bin/test1.bin -o ./build/bin/result.bin)
Source Code:
oneAPI.zip
OS Version: RHEL 8.1 (Ootpa)
oneAPI Base Toolkit Version Beta 10
clinfo:
clinfo.txt
Thank you
GouthamK_Intel
Thanks for providing the source code and steps to reproduce!
We are forwarding this thread to Subject Matter Expert who will help you in resolving the issue.
Have a Good day!
Goutham
Subarnarek_G_Intel
Looking into the case. Will get back to you soon.
jwong545
I haven't heard any updates since last time Subarnarek_G_Intel replied. How's the case situation?
Hewitt__Archie
Get the same problem.
Any updates in this topic?
Subarnarek_G_Intel
With gold compiler I am getting a couple of issues compiling the code. Can you try with oneAPI Gold once?
GouthamK_Intel
As we have not heard back from you, we are considering that your issue has been resolved and we have answered all your queries. So we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Have a Good day!
Thanks & Regards
Goutham
