Hi everyone,
I am trying to compile the vector_add example from BaseKit_code_samples and I am getting an error related to the Quartus path.
-What I have done:
~/BaseKit-code-samples/DPC++Compiler/vector-add$ qsub -l nodes=1:fpga_compile:ppn=2 -d . build_fpga_hw.sh
-build_fpga_hw.sh contains:
#!/bin/bash source /opt/intel/inteloneapi/setvars.sh make hw -f Makefile.fpga
-I am getting the following error:
aoc: Quartus is not on the path! aoc: Is it installed on your system and quartus bin directory added to PATH environment variable? /home/u36780/tmp/vector-add-5577cc.o: file not recognized: File truncated clang++: error: fpga compiler command failed with exit code 1 (use -v to see invocation) clang++: error: linker command failed with exit code 1 (use -v to see invocation) make: *** [vector-add.fpga] Error 1 /var/spool/torque/mom_priv/epilogue.parallel: line 12: /var/spool/torque/mom_priv/epilogue.d//95-nvdir.epilogue: Permission denied
I have tried to manually set the environment variables of quartus adding the following line in build_fpga_hw.sh:(I have tried all the versions contained in that folder)
source /glob/development-tools/versions/intelFPGA_pro/18.1/init_quartus.sh
But I got another error related to quartus:
: :setvars has already been run. Skipping any further invocation. To force its re-execution, pass --force dpcpp -fintelfpga a.o -o vector-add.fpga -Xshardware aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. Error (18640): The Quartus Partition Database File '/home/u36780/tmp/a-f8684f/build/dcp.qdb' was generated using version 'Version 17.1.1 Build 273 12/19/2017 SJ Pro Edition', which cannot be read by the c$ Error (19296): Cannot load none snapshot - ensure the design has been compiled through all earlier stages. Error (19829): dcp.qdb cannot be assigned. The dcp.qdb file is missing Partial Reconfiguration or Reserved Core subpartitions and assigned to the root partition. In order to assign a QDB file to the root $ Error (18640): The Quartus Partition Database File '/home/u36780/tmp/a-f8684f/build/bsp_interface.qdb' was generated using version 'Version 17.1.1 Build 273 12/19/2017 SJ Pro Edition', which cannot be rea$ Error: Flow failed: Error (23035): Tcl error: Error (23031): Evaluation of Tcl script compile_script.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings Error (23035): Tcl error: Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings Makefile.fpga:17: recipe for target 'vector-add.fpga' failed
I thought that maybe the error was related to the oneAPI layer, so I tried to compile the same example from the OpenCL examples, but unfortunately, I found the same error:
For both oneAPI & OpenCL I have tried in fpga_complie node, fpga_runtime and interative mode. Any options gave me the same error.
Basic compilation:
~/examples_aoc/vector_add/device$ aoc -v -board=pac_a10 vector_add.cl -o vector_add.aocx aoc: Environment checks completed successfully. aoc: Quartus is not on the path! aoc: Is it installed on your system and quartus bin directory added to PATH environment variable?
Adding quartus environment variable:
~/examples_aoc/vector_add/device$ source /glob/development-tools/versions/intelFPGA_pro/18.1/init_quartus.sh ~/examples_aoc/vector_add/device$ aoc -v -board=pac_a10 vector_add.cl -o vector_add.aocx aoc: Environment checks completed successfully. aoc: Cached files in /var/tmp/aocl/ may be used to reduce compilation time You are now compiling the full flow!! aoc: Selected target board pac_a10 aoc: Running OpenCL parser.... aoc: OpenCL parser completed aoc: Linking Object files.... aoc: Optimizing and doing static analysis of code... Compiler Warning: vector_add.cl:23: declaring global arguments 'x' and 'y' with no 'restrict' may lead to low performance for kernel 'vector_add' aoc: Linking with IP library ... aoc: Checking if memory usage is larger than 100%... aoc: Memory usage is not above 100. aoc: First stage compilation completed successfully. aoc: Compiling for FPGA. This process may take several hours to complete. Prior to performing this compile, be sure to check the reports to ensure the design will meet your performance targets. If the reports indicate performance targets are not being met, code edits may be required. Please refer to the Intel FPGA SDK for OpenCL Best Practices Guide for information on performance tuning applications for FPGAs. Error (18640): The Quartus Partition Database File '/home/u36780/examples_aoc/vector_add/device/vector_add/build/dcp.qdb' was generated using version 'Version 17.1.1 Build 273 12/19/2017 SJ Pro Edition', which cannot be read by the current version of the Quartus Prime software. Regenerate '/home/u36780/examples_aoc/vector_add/device/vector_add/build/dcp.qdb' using the current version of the Quartus Prime Software. Error (19296): Cannot load none snapshot - ensure the design has been compiled through all earlier stages. Error (19829): dcp.qdb cannot be assigned. The dcp.qdb file is missing Partial Reconfiguration or Reserved Core subpartitions and assigned to the root partition. In order to assign a QDB file to the root partition, it must be created from a design using Partial Reconfiguration or Reserved Core subpartitions. To correct this error, ensure that the creation and assignment of the QDB is correct. Error (18640): The Quartus Partition Database File '/home/u36780/examples_aoc/vector_add/device/vector_add/build/bsp_interface.qdb' was generated using version 'Version 17.1.1 Build 273 12/19/2017 SJ Pro Edition', which cannot be read by the current version of the Quartus Prime software. Regenerate '/home/u36780/examples_aoc/vector_add/device/vector_add/build/bsp_interface.qdb' using the current version of the Quartus Prime Software. Error: Flow failed: Error (23035): Tcl error: Error (23031): Evaluation of Tcl script compile_script.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings Error (23035): Tcl error: Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings Error: Compiler Error, not able to generate hardware
Does anyone have any clue about how to solve this issue?
Thanks a lot.
- Tags:
- Bug
We are closing this thread due to the duplication, you can track its progress on "Quartus path fails to compile BaseKit-sample on oneAPI&OpenCL" thread.
-Abhishek
