Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Run sample project in Wndows VS2019
nnain1
I have problem running sample projects in Windows.
(1)Using oneapi command pront, oneapi-cli produced a windows sample project.
The solution file was opened. But I can't build and it has errors at
#include <CL/sycl.hpp>
using namespace cl::sycl;
Then still have a lot of errors as shown in the image.
Do I still need to link to header files and libraries.
If so, where are oneapi include files and libraries.
Is it in this
C:\Program Files (x86)\inteloneapi
installed folder?
But can't find CL folder?
(2) According to discussion here,
https://software.intel.com/en-us/get-started-with-intel-oneapi-windows-iot-run-a-sample-project-using-an-ide
I should be able to find Extentions > Intel > Open an Intel oneAPI Sample.
But saw only Manage Extensions.
How to have Extentions > Intel > Open an Intel oneAPI Sample in VS2019?
nnain1
Yes it works now.
RahulV_intel
It looks like there is an integration issue with your VS-2019. Download the latest version of the base-toolkit here. Refer to the installation guide here. Post successful installation, you will be able to see "Extentions > Intel > Open an Intel oneAPI Sample".
nnain1
Yes it works now.
RahulV_intel
Thanks for the confirmation. We are closing this thread.
