Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
394 Discussions
Start Nativelink Simulation process
niraz
Info: Start Nativelink Simulation process
Error: Run Analysis and Elaboration successfully before starting RTL NativeLink Simulation
Analysis and Synthesis should be completed successfully before starting RTL NativeLink Simulation
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: 1
Nativelink TCL script failed with errorInfo: 1
invoked from within
"if ![qmap_successfully_completed] {
nl_postmsg error "Error: Run Analysis and Elaboration successfully before starting RTL NativeLink Simu..."
(procedure "run_eda_simulation_tool" line 232)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
niraz
Please, help to solve this issue
