Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
USM with CUDA backend
eug
I'm trying to build a DPCPP application to run with a CUDA backend.
I'm using this guide as reference https://intel.github.io/llvm-docs/GetStartedGuide.html#build-dpc-toolchain-with-support-for-nvidia-cuda .
The application works well if I don't use the USM extension. If I use it, I get an exception.
My question is:  is USM supported by the cuda backend?
RahulV_intel
Please note that  oneAPI-beta08 does not support CUDA backend currently. However, the alternate version (available on github) does support CUDA backend.
https://github.com/intel/llvm/blob/sycl/sycl/doc/GetStartedGuide.md
For any issues related to this, I would highly encourage you to open an issue on github itself, for faster response.
Link: https://github.com/intel/llvm/issues
Rahul
RahulV_intel
Rahul
RahulV_intel
Let me know if I may close this thread from my end.
Rahul
eug
RahulV_intel
Thanks for the confirmation.
Intel will no longer monitor this thread. Henceforth, any discussion on this thread will be considered as a community response.
