Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
Unable to access YUM repository
Jan_Gerrit_Kootstra
I get a http 403 Forbidden message when running the command:
sudo yum install intel-basekit
SoniaRani_G_Intel
Hi Jan,
Can you please try to install intel basekit from with other method?
Here is the following link from where you can directly download intel-basekit.
https://dynamicinstaller.intel.com/oneapi/toolkits/base-kit/linux/
Sonia
WILLIAM_H_Intel4
Hi Jan, can you please provide some detail about your environment?  Are you running this on the DevCloud, or something else?
William.
Muhammad_Shahzad_S_
I face the same error when using Fedora31 64bit on my laptop,
[root@rose ~]# yum -v install intel-basekit
Loaded plugins: builddep, changelog, config-manager, copr, debug, debuginfo-install, download, generate_completion_cache, needs-restarting, playground, repoclosure, repodiff, repograph, repomanage, reposync
DNF version: 4.2.9
cachedir: /var/cache/dnf
Unknown configuration value: failovermethod=priority in /etc/yum.repos.d/fedora-updates-modular.repo; Configuration: OptionBinding with id "failovermethod" does not exist
repo: using cache for: fedora-modular
fedora-modular: using metadata from Fri 25 Oct 2019 03:48:21 AM CEST.
repo: using cache for: updates-modular
updates-modular: using metadata from Mon 04 Nov 2019 05:53:53 AM CET.
updates: using metadata from Mon 04 Nov 2019 01:46:21 AM CET.
fedora: using metadata from Fri 25 Oct 2019 03:48:20 AM CEST.
repo: using cache for: google-chrome
google-chrome: using metadata from Fri 01 Nov 2019 08:05:13 PM CET.
repo: downloading from remote: oneAPI
error: Status code: 403 for http://1a.sandbox.intel.com.s3.amazonaws.com/yum/oneapi/repodata/repomd.xml (http://1a.sandbox.intel.com.s3.amazonaws.com/yum/oneapi/repodata/repomd.xml).                      ] 601  B/s | 243  B     --:-- ETA
Intel(R) oneAPI repository        256  B/s | 243  B     00:00
Cannot download 'http://1a.sandbox.intel.com.s3.amazonaws.com/yum/oneapi': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried.
Failed to download metadata for repo 'oneAPI'
repo: using cache for: rpmfusion-free-updates
rpmfusion-free-updates: using metadata from Sun 03 Nov 2019 04:17:47 PM CET.
rpmfusion-free: using metadata from Tue 22 Oct 2019 12:21:36 PM CEST.
repo: using cache for: rpmfusion-nonfree-updates
rpmfusion-nonfree-updates: using metadata from Sun 03 Nov 2019 04:24:22 PM CET.
rpmfusion-nonfree: using metadata from Tue 22 Oct 2019 12:43:47 PM CEST.
Ignoring repositories: oneAPI
Last metadata expiration check: 0:59:51 ago on Mon 04 Nov 2019 11:16:43 AM CET.
Completion plugin: Generating completion cache...
No match for argument: intel-basekit
Error: Unable to find a match: intel-basekit
So far I have tried tried with openSuse 15.1 and Fedora 31 (both are 64bit). repo URLs work neither for yum nor for zypper. I am going to give it a shot with Ubuntu 18.04 64bit tonight and let you know if that works.
Thank you.
SoniaRani_G_Intel
Hi Jan,
Sonia
Ron_Green
If your systems are inside the Intel Intranet you will need to set up proxys with env vars.  And remember, if you 'sudo' you need to use the -E argument to carry your env vars over to the sudo shell.
I'd recommend trying this:
sudo bash
<password>
export http_proxy=http://proxy-us.intel.com:911
export https_proxy=http://proxy-us.intel.com:911
export HTTP_PROXY=http://proxy-us.intel.com:911
export HTTPS_PROXY=http://proxy-us.intel.com:911
apt-get install intel-basekit
similar for YUM and Zypper.  It's the same issue you have for accessing public GITHUB from inside the Intel Firewall. You need to have the HTTP/S proxies set up for apt or yum or Zypper to get out.
If you have a choice, use Ubu 18.04 as this is the oneAPI tools are primarily developed and tested on this OS.
ron
Jan_Gerrit_Kootstra
All,
I have been late from work the last few days.
I am running the download option provided by https://dynamicinstaller.intel.com/oneapi/toolkits/base-kit/linux/
The zip file has downloaded without any issues.
./install.sh is still downloading the software.
Thanks for all the hints.
Jan Gerrit
Pradeep_G_Intel
Hi Jan,
We are glad to hear that we could help you.
Pradeep
