Hii,
I have working been working on Intel oneAPI from beta-06, when I have gone through few applications, I am unable to migrate below Cuda API's using dpct and facing the below mentioned warning.
warning: DPCT1007:3: Migration of this CUDA API is not supported by the Intel(R) DPC++ Compatibility Tool.
cufftPlanMany
cufftSetStream
cufftDestroy
cuErrorCheck
mycufftExecC2R
_threadfence
curand_init
curand_normal
curand_uniform
_ldg
curand_uniform_double
cudaProfilerStart
cudaProfilerStop
curand_normal_double
cuGetErrorString
cuPointerGetAttributes
cudaMemcpyDefault
cudaLaunchKernel
cuGetErrorName
cuEventQuery
cuEventRecord
cuStreamWaitEvent
cuStreamSynchronize
cuEventSynchronize
cuCtxSynchronize
_syncwarp
Can we find any replacement for the above Cuda API's , so that it can be migrated using dpct?
Please try using the latest Intel OneAPI Basekit ie beta-09.
The latest release has started to support most of the API (some partially) that you have mentioned like curand, cufft, etc.
DPC++ has its own mechanism to handle errors, so I will suggest you use the dpc++ error handling technique in such cases.
Please refer to the below links for more details.
Warm Regards,
Abhishek
Please give us an update on the details.
Thank you
We haven't heard back from you, so we are assuming that the provided details helped you in solving your issue. We will no longer monitor this thread.
Please post a new thread if you have any other issues.
Warm Regards,
Abhishek
