Hi, If I use two different processes and each process have its own execution context and SYCL queue(s) associated with the device(s) it is using. Each process explicitly copy data between the host and device(s) using the SYCL memory management functions and commands.How to share the data in device with two processes
Since this is a continuation thread of https://community.intel.com/t5/Intel-C-Compiler/Unified-Shared-Memory/m-p/1482659#M40953, we will
no longer monitor this thread. We will continue addressing
your issue in the other thread.
We request you to post your responses related to this thread in the above mentioned query.
Thanks & Regards,
Noorjahan.
