Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
Using oneCCL API with SYCL Level Zero backend without DPC++
sogartar
I have oneCCL prebuilt and I want to use it. I don't want to compile my binary with DPC++. Is this possible?
oneCCL seem to require DPC++ even when you just use it. In config.h there is this
#if defined(SYCL_LANGUAGE_VERSION) && defined (__INTEL_LLVM_COMPILER)
#define CCL_ENABLE_SYCL
#define CCL_ENABLE_ZE
#endif
These defines then drive the availability of the SYCL backend in the oneCCL API. Is DPC++ really necessary?
SantoshY_Intel
As mentioned in the Intel® oneAPI Collective Communications Library System Requirements, is required to have Intel® oneAPI DPC++/C++ Compiler 2021.1 or higher and DPC++ Runtime 2021.1 or higher.
So, you can't use CLANG or GCC alone to use oneCCL.
Thanks & Regards,
Santosh
SantoshY_Intel
Thanks for posting in the Intel forums.
>>"I don't want to compile my binary with DPC++. Is this possible?"
Yes, you can use the ICPX compiler instead of the DPC++ compiler.
If it doesn't work, then please provide us with the sample reproducer code & the steps to reproduce the issue from our end.
Thanks & Regards,
Santosh
sogartar
I want to use it with GCC or clang. I am pretty sure that __INTEL_LLVM_COMPILER would not be defined there.
SantoshY_Intel
Thanks & Regards,
Santosh
SantoshY_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
