Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
370 Discussions
VS2022 with IntelCppCompiler2022: unkonwn MMX
yuZou
I have a solution which can be built correctly with VS2019 16.7.8 and IntelCppCompiler 19.0.
Now I am trying to build it with VS2022 17.0.2 and IntelCppCompiler 2022.
But I got several errors about mmx as below:
What could be the problem, and corresponding solution?
VarshaS_Intel
Could you please let us know the C++ compiler version you are using?
And also, could you please provide us with the sample reproducer code along with the steps to reproduce the error?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
