Dear ALL,
I am planning to use VTune to profile codes. There are some problems I met and hope to get ideas.
(1). Warnings when installing VTune:
There are one or more unresolved issues based on your system configuration a
nd component selection
You can resolve all the issues without exiting the installer and re-check, o
r you can exit, resolve the issues, and then run the Installation again.
ue to Installation and resolve them later) |
XCB package is not installed |
Intel® VTune(TM) Profiler requires XCB library for graphical user in |
terface, it can be installed with |
sudo apt-get install libxcb-dri3-0 |
on Ubuntu / Debian |
sudo zypper install libxcb1 on SUSE |
sudo dnf ins X
tall libxcb on CentOS / RHEL / Fedora |
DRM package is not installed |
Intel® VTune(TM) Profiler requires DRM library for graphical user in |
sudo apt-get install libdrm2 on Ub |
untu / Debian |
sudo zypper install libdrm2 on SUSE
However, I have checked and ensured that both libxcb-dri3-0 and libdrm2 have been installed. Even though I can ignore these two warnings and continue to install, I am quite confused with the warnings.
Besides, since I want to profile codes with multiply cores, the sampling dirvers are quite necessary for me. However, I cannot install drivers since I cannot successfully build and load dirvers:
For the Step 5 in /sepdk/src/README.txt:
I got the problem loading the dirver to kernel:
--------------------- Loading PAX driver ---------------------
Checking for PMU arbitration service (PAX) ... not detected.
Attempting to start PAX service ...
Executing: insmod ./pax/pax-x32_64-5.15.0-53-genericsmp.ko
./pax/insmod-pax: 520: [: False: unexpected operator
insmod: ERROR: could not insert module ./pax/pax-x32_64-5.15.0-53-genericsmp.ko: Operation not permitted
ERROR: pax driver failed to load!
ERROR: failed to start or connect to required PAX service
