Intel® oneAPI Base Toolkit
Support for core tools and libraries to build and deploy high-performance data-centric applications
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
287 Discussions
When I open MVS 2019 I get a message "The Samples feed is empty"
galli_m
Can anyone tell me what this means?
If this is not important, how do I keep it from popping up every time?
Thank you.
ChrisB_Intel
galli_m
My apologies for the delay on getting back to you. Would you please disable the sample plugin, You can find it under menu "extensions > manage extensions", "Intel oneAPI Menu & Samples". Please disable it and see if the msg still pops up and let me know the results?
Chris
GaoLei
same problem
ArpitaP_Intel
Hi
Please let us know, if this issue was encountered after installing Intel oneAPI Base Toolkit and then integrating it with Microsoft Visual Studio 2019. A bit more elaboration of reproducing it can help us understand your issue better.
Also, please let us know the version of your Microsoft Visual Studio 2019, Intel oneAPI Base toolkit and the OS used.
Arpita Panda
galli_m
I installed Visual Studio 2019 (community) ver. 16.9.3
in early April 2021. Then I installed
Intel oneAPI Base (w_BaseKit_p_2021.2.0.2871_offline.exe)
then HPC toolkit (w_HPCKit_p_2021.2.0.2901_offline.exe)
I have also upgraded to VS 2019 ver. 16.9.4 more recently.
I have not had any problems.
This issue only started after I disconnected my computer
from the web. (I have to do this now)
I would be interested to know if 'GaoLei' had this issue
the same way...
I'm running this on Windows 10 Pro with
Intel Core I5-10600K 6-Core, 12-Thread desktop.
I hope this helps.
Thank you for your effort.
Please note that I am interested in preventing this pop-up
more than anything else.
It is not affecting my work at present. I assume "samples"
refers to program/code samples...??
Soumya_M_Intel
Thanks for providing the details. First of all, we would like to check and confirm if it is an integration issue or not. Please follow the below steps:
  • Go to the 'About' option from the 'Help' section of the Visual Studio.
  • Scroll through the list of integrated components to check if the Intel® oneAPI toolkit's components are there or not.
Please get back to us with a screenshot of the same if you find them. Do let us know if none of the components are available on that list. It will provide us a better understanding of the issue. Looking forward to your findings.
Soumya
galli_m
Below is a copy of the list of installed products.....
Microsoft Visual Studio Community 2019
Version 16.9.4
VisualStudio.16.Release/16.9.4+31205.134
Microsoft .NET Framework
Version 4.8.04084
Installed Version: Community
Visual C++ 2019 00435-60000-00000-AA954
Microsoft Visual C++ 2019
ASP.NET and Web Tools 2019 16.9.693.2781
C# Tools 3.9.0-6.21160.10+59eedc33d35754759994155ea2f4e1012a9951e3
C# components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Intel Libraries for oneAPI Package ID: w_oneAPI_2021.2.0.243
Intel Libraries for oneAPI – toolkit version: 2021.2.0, extension version 21.1.0.16, Package ID: w_oneAPI_2021.2.0.243, Copyright © 2019-2021 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others.
Intel® Advisor 2021.2 609067
Intel® Advisor 2021.2, (build 609067), Copyright © 2009-2021 Intel Corporation. All rights reserved.
Intel® C++ Compiler Package ID: w_oneAPI_2021.2.0.243
Intel® C++ Compiler – toolkit version: 2021.2.0, extension version 21.0.16, Package ID: w_oneAPI_2021.2.0.243, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® C++ Compiler Classic Package ID: w_oneAPI_2021.2.0.243
Intel® C++ Compiler Classic – toolkit version: 2021.2.0, extension version 19.2.6.16, Package ID: w_oneAPI_2021.2.0.243, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® Distribution for GDB* 1.0
Provides debugging capabilities for compute shaders running on the Intel GPU.
Intel® DPC++ Compatibility Tool Package ID: w_oneAPI_2021.2.0.221
Intel® DPC++ Compatibility Tool – toolkit version: 2021.2.0, extension version 2021.1.0.16, Package ID: w_oneAPI_2021.2.0.221, Copyright © 2019-2021 Intel Corporation. All rights reserved.
Intel® Fortran Compiler Package ID: w_oneAPI_2021.2.0.243
Intel® Fortran Compiler – toolkit version: 2021.2.0, extension version 19.2.0061.16, Package ID: w_oneAPI_2021.2.0.243, Copyright © 2002-2021 Intel Corporation. All rights reserved.
Intel® Inspector 2021.2 605251
Intel® Inspector 2021.2, (build 605251), Copyright © 2009-2021 Intel Corporation. All rights reserved.
Intel® oneAPI DPC++ Compiler Package ID: w_oneAPI_2021.2.0.243
Intel® oneAPI DPC++ Compiler – toolkit version: 2021.2.0, extension version 21.1.0.16, Package ID: w_oneAPI_2021.2.0.243, Copyright © 2019-2021 Intel Corporation. All rights reserved.
Intel® oneAPI Menu & Samples 1.1.398
Intel® oneAPI Visual Studio Menu & Samples Extension
Intel® VTune™ Profiler 2021 615922
Intel® VTune™ Profiler 2021, (build 615922), Copyright © 2009-2021 Intel Corporation. All rights reserved.
IntelliCode Extension 1.0
IntelliCode Visual Studio Extension Detailed Info
Microsoft JVM Debugger 1.0
Provides support for connecting the Visual Studio debugger to JDWP compatible Java Virtual Machines
Microsoft MI-Based Debugger 1.0
Provides support for connecting Visual Studio to MI compatible debuggers
Microsoft Visual C++ Wizards 1.0
Microsoft Visual Studio VC Package 1.0
NuGet Package Manager 5.9.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit https://docs.nuget.org/
ProjectServicesPackage Extension 1.0
ProjectServicesPackage Visual Studio Extension Detailed Info
Test Adapter for Boost.Test 1.0
Enables Visual Studio's testing tools with unit tests written for Boost.Test. The use terms and Third Party Notices are available in the extension installation directory.
Test Adapter for Google Test 1.0
Enables Visual Studio's testing tools with unit tests written for Google Test. The use terms and Third Party Notices are available in the extension installation directory.
TypeScript Tools 16.0.30201.2001
TypeScript Tools for Microsoft Visual Studio
Visual Basic Tools 3.9.0-6.21160.10+59eedc33d35754759994155ea2f4e1012a9951e3
Visual Basic components used in the IDE. Depending on your project type and settings, a different version of the compiler may be used.
Visual Studio Code Debug Adapter Host Package 1.0
Interop layer for hosting Visual Studio Code debug adapters in Visual Studio
Visual Studio Tools for CMake 1.0
Soumya_M_Intel
Thanks for providing the list. I am currently checking on the issue with our internal team. We will get back to you as soon as possible.
Soumya
Soumya_M_Intel
Thanks for your patience while we are working on the issue. This is to update you that we were able to replicate the message and are checking with our higher team regarding it. However, we would like to confirm if the attached image has the same issue that you had faced.
Soumya
Edit I: The screenshot has been reattached now.
galli_m
Soumya_M_Intel
Thanks for the confirmation. I am checking on it with our higher team. I will get back to you soon.
Soumya
ChrisB_Intel
galli_m
Chris
galli_m
When I opened VS as 'administrator'... and disabled... it worked.
Thank you
Soumya_M_Intel
Hi galli_m,
Thanks for providing the update on the post. Glad to know that it worked. Proceeding further, I am closing this thread. However, feel free to create a new thread if there are any queries or concerns. Have a nice day!
Soumya
