Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
apt-get issues - 403 Forbidden IP errors
jitendra42
Trying to install basekit in docker container... apt-get is throwing 403 Forbidden IP errors.  is there anything that I am missing here?
Step 32/34 : RUN wget https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS-2023.PUB && apt-key add GPG-PUB-KEY-INTEL-SW-PRODUCTS-2023.PUB && rm GPG-PUB-KEY-INTEL-SW-PRODUCTS-2023.PUB && add-apt-repository "deb https://apt.repos.intel.com/oneapi all main"
---> Using cache
---> 286d39709db4
Step 33/34 : RUN sudo apt-get update --fix-missing && sudo apt-get install -y intel-basekit
---> Running in 71faa1895ab2
Hit:1 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal InRelease
Hit:2 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal-updates InRelease
Hit:3 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal-security InRelease
Hit:4 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal-backports InRelease
Get:5 https://osgc.jf.intel.com/internal/ubuntu focal-embargo-ats-untested InRelease [3,279 B]
Hit:6 https://apt.repos.intel.com/oneapi all InRelease
Fetched 3,279 B in 1s (4,501 B/s)
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
cmake cmake-data intel-basekit-getting-started intel-oneapi-advisor
intel-oneapi-ccl-2021.1-beta10 intel-oneapi-ccl-devel
intel-oneapi-ccl-devel-2021.1-beta10 intel-oneapi-common-licensing
intel-oneapi-common-licensing-2021.1-beta10 intel-oneapi-common-vars
intel-oneapi-compiler-shared-2021.1-beta10
intel-oneapi-compiler-shared-common-2021.1-beta10
intel-oneapi-compiler-shared-common-runtime-2021.1-beta10
intel-oneapi-compiler-shared-runtime-2021.1-beta10 intel-oneapi-condaindex
intel-oneapi-cpp-compiler-eclipse-cfg intel-oneapi-dal
intel-oneapi-dal-2021.1-beta10 intel-oneapi-dal-common-2021.1-beta10
intel-oneapi-dal-common-devel-2021.1-beta10 intel-oneapi-dal-devel
intel-oneapi-dal-devel-2021.1-beta10 intel-oneapi-dev-utilities
intel-oneapi-dev-utilities-2021.1-beta10
intel-oneapi-dev-utilities-eclipse-cfg intel-oneapi-dnnl
intel-oneapi-dnnl-devel intel-oneapi-dpcpp-compiler-eclipse-cfg
intel-oneapi-dpcpp-cpp-2021.1-beta10 intel-oneapi-dpcpp-cpp-compiler
intel-oneapi-dpcpp-cpp-compiler-2021.1-beta10
intel-oneapi-dpcpp-cpp-compiler-common-2021.1-beta10
intel-oneapi-dpcpp-cpp-compiler-runtime-2021.1-beta10 intel-oneapi-dpcpp-ct
intel-oneapi-dpcpp-ct-2021.1-beta10 intel-oneapi-dpcpp-ct-eclipse-cfg
intel-oneapi-dpcpp-debugger intel-oneapi-dpcpp-debugger-10.0-beta10
intel-oneapi-dpcpp-debugger-eclipse-cfg intel-oneapi-ipp
intel-oneapi-ipp-2021.1-beta09 intel-oneapi-ipp-common-2021.1-beta09
intel-oneapi-ipp-common-devel-2021.1-beta09 intel-oneapi-ipp-devel
intel-oneapi-ipp-devel-2021.1-beta09 intel-oneapi-ippcp-2021.1-beta09
intel-oneapi-ippcp-common-2021.1-beta09
intel-oneapi-ippcp-common-devel-2021.1-beta09 intel-oneapi-ippcp-devel
intel-oneapi-ippcp-devel-2021.1-beta09 intel-oneapi-libdpstd-devel
intel-oneapi-libdpstd-devel-2021.1-beta10 intel-oneapi-mkl
intel-oneapi-mkl-2021.1-beta10 intel-oneapi-mkl-common-2021.1-beta10
intel-oneapi-mkl-common-devel-2021.1-beta10 intel-oneapi-mkl-devel
intel-oneapi-mkl-devel-2021.1-beta10 intel-oneapi-mpi
intel-oneapi-mpi-2021.1-beta10 intel-oneapi-mpi-devel
intel-oneapi-mpi-devel-2021.1-beta10 intel-oneapi-onevpl-2021.1-beta10
intel-oneapi-onevpl-devel intel-oneapi-onevpl-devel-2021.1-beta10
intel-oneapi-openmp intel-oneapi-openmp-2021.1-beta10
intel-oneapi-openmp-common-2021.1-beta10 intel-oneapi-python
intel-oneapi-tbb intel-oneapi-tbb-2021.1-beta10
intel-oneapi-tbb-common-2021.1-beta10
intel-oneapi-tbb-common-devel-2021.1-beta10 intel-oneapi-tbb-devel
intel-oneapi-tbb-devel-2021.1-beta10 intel-oneapi-vtune libarchive13 libbsd0
libdrm-common libdrm2 libjsoncpp1 libpciaccess0 librhash0 libuv1 libx11-6
libx11-data libxau6 libxcb1 libxdmcp6 libxext6 libxfixes3
Suggested packages:
cmake-doc ninja-build lrzip pciutils
The following NEW packages will be installed:
cmake cmake-data intel-basekit intel-basekit-getting-started
intel-oneapi-advisor intel-oneapi-ccl-2021.1-beta10 intel-oneapi-ccl-devel
0 upgraded, 92 newly installed, 0 to remove and 3 not upgraded.
Need to get 3,288 MB of archives.
After this operation, 15.2 GB of additional disk space will be used.
Get:1 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libbsd0 amd64 0.10.0-1 [45.4 kB]
Get:2 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal-updates/main amd64 libuv1 amd64 1.34.2-1ubuntu1.1 [80.4 kB]
Get:3 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libxau6 amd64 1:1.0.9-0ubuntu1 [7,488 B]
Get:4 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libxdmcp6 amd64 1:1.1.3-0ubuntu1 [10.6 kB]
Get:5 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libxcb1 amd64 1.14-2 [44.7 kB]
Get:6 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal-updates/main amd64 libx11-data all 2:1.6.9-2ubuntu1.1 [113 kB]
Get:7 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal-updates/main amd64 libx11-6 amd64 2:1.6.9-2ubuntu1.1 [574 kB]
Get:8 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libxext6 amd64 2:1.3.4-0ubuntu1 [29.1 kB]
Get:9 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 cmake-data all 3.16.3-1ubuntu1 [1,612 kB]
Get:10 https://osgc.jf.intel.com/internal/ubuntu focal-embargo-ats-untested/main amd64 libdrm-common all 2.4.103+embargo374 [14.8 kB]
Get:11 https://osgc.jf.intel.com/internal/ubuntu focal-embargo-ats-untested/main amd64 libdrm2 amd64 2.4.103+embargo374 [41.6 kB]
Get:12 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libarchive13 amd64 3.4.0-2ubuntu1 [327 kB]
Get:13 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libjsoncpp1 amd64 1.7.4-3.1ubuntu2 [75.6 kB]
Get:14 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 librhash0 amd64 1.3.9-1 [113 kB]
Get:15 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 cmake amd64 3.16.3-1ubuntu1 [3,669 kB]
Get:16 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libpciaccess0 amd64 0.16-0ubuntu1 [17.9 kB]
Get:17 http://linux-ftp.ostc.intel.com/pub/mirrors/ubuntu focal/main amd64 libxfixes3 amd64 1:5.0.3-2 [10.9 kB]
Ign:18 https://apt.repos.intel.com/oneapi all/main amd64 intel-basekit-getting-started all 2021.1-2261.beta10
Get:19 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-common-licensing-2021.1-beta10 all 2021.1-606.beta10 [42.2 kB]
Get:20 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-common-licensing all 2021.1-606.beta10 [2,304 B]
Get:21 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-common-vars all 2021.1-606.beta10 [12.0 kB]
Err:22 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-vtune amd64 2021.1-739.beta10
403 Forbidden [IP: 10.22.230.62 912]
Get:23 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dev-utilities-eclipse-cfg all 2021.1-2505.beta10 [1,882 B]
Get:24 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dev-utilities-2021.1-beta10 amd64 2021.1-2505.beta10 [12.4 MB]
Get:25 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dev-utilities amd64 2021.1-2505.beta10 [2,300 B]
Get:26 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-tbb-common-2021.1-beta10 all 2021.1-2317.beta10 [29.1 kB]
Get:27 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-condaindex amd64 2021.1-558.beta07 [21.5 MB]
Get:28 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-tbb-2021.1-beta10 amd64 2021.1-2317.beta10 [1,899 kB]
Get:29 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-tbb-common-devel-2021.1-beta10 all 2021.1-2317.beta10 [167 kB]
Get:30 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-tbb-devel-2021.1-beta10 amd64 2021.1-2317.beta10 [701 kB]
Get:31 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-tbb-devel amd64 2021.1-2317.beta10 [1,868 B]
Get:32 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mpi-2021.1-beta10 amd64 2021.1-2190.beta10 [20.8 MB]
Get:33 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mpi amd64 2021.1-2190.beta10 [1,652 B]
Err:34 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ccl-2021.1-beta10 amd64 2021.1-1101.beta10
Err:35 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mpi-devel-2021.1-beta10 amd64 2021.1-2190.beta10
Err:36 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mpi-devel amd64 2021.1-2190.beta10
Err:37 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ccl-devel-2021.1-beta10 amd64 2021.1-1101.beta10
Err:38 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ccl-devel amd64 2021.1-1101.beta10
Get:39 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-compiler-shared-common-runtime-2021.1-beta10 all 2021.1-2496.beta10 [13.2 MB]
Get:40 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-compiler-eclipse-cfg all 2021.1-2496.beta10 [1,948 B]
Get:41 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-cpp-compiler-eclipse-cfg all 2021.1-2496.beta10 [2,000 B]
Get:42 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-cpp-compiler-common-2021.1-beta10 all 2021.1-2496.beta10 [1,373 kB]
Get:43 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-openmp-common-2021.1-beta10 all 2021.1-2496.beta10 [13.9 kB]
Get:44 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-openmp-2021.1-beta10 amd64 2021.1-2496.beta10 [239 MB]
Get:45 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-compiler-shared-runtime-2021.1-beta10 amd64 2021.1-2496.beta10 [5,804 kB]
Get:46 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-tbb amd64 2021.1-2317.beta10 [1,846 B]
Get:47 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-cpp-compiler-runtime-2021.1-beta10 amd64 2021.1-2496.beta10 [154 MB]
Get:48 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-compiler-shared-common-2021.1-beta10 all 2021.1-2496.beta10 [99.7 MB]
Get:49 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-compiler-shared-2021.1-beta10 amd64 2021.1-2496.beta10 [14.0 MB]
Get:50 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-cpp-2021.1-beta10 amd64 2021.1-2496.beta10 [420 MB]
Get:51 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-libdpstd-devel-2021.1-beta10 amd64 2021.1-2496.beta10 [169 kB]
Get:52 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-cpp-compiler-2021.1-beta10 amd64 2021.1-2496.beta10 [1,696 B]
Get:53 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-cpp-compiler amd64 2021.1-2496.beta10 [1,656 B]
Err:54 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-libdpstd-devel amd64 2021.1-2496.beta10
Ign:55 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-debugger-eclipse-cfg all 10.0-2174.beta10
Err:56 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-debugger-10.0-beta10 amd64 10.0-2174.beta10
Err:57 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-debugger amd64 10.0-2174.beta10
Err:58 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-onevpl-2021.1-beta10 amd64 2021.1-664.beta10
Err:59 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-onevpl-devel-2021.1-beta10 amd64 2021.1-664.beta10
Err:60 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-onevpl-devel amd64 2021.1-664.beta10
Get:61 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-openmp amd64 2021.1-2496.beta10 [2,428 B]
Err:62 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dnnl amd64 2021.1-2144.beta10
Err:63 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dnnl-devel amd64 2021.1-2144.beta10
Ign:64 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-common-2021.1-beta10 all 2021.1-2300.beta10
Err:65 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-2021.1-beta10 amd64 2021.1-2300.beta10
Ign:66 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-common-devel-2021.1-beta10 all 2021.1-2300.beta10
Err:67 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-devel-2021.1-beta10 amd64 2021.1-2300.beta10
Err:68 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-devel amd64 2021.1-2300.beta10
Ign:69 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-ct-eclipse-cfg all 2021.1-718.beta10
Err:70 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-ct-2021.1-beta10 amd64 2021.1-718.beta10
Err:71 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-ct amd64 2021.1-718.beta10
Err:72 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-advisor amd64 2021.1-668.beta10
Get:73 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mkl-common-2021.1-beta10 all 2021.1-2304.beta10 [21.9 kB]
Get:74 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mkl-2021.1-beta10 amd64 2021.1-2304.beta10 [191 MB]
Get:75 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mkl-common-devel-2021.1-beta10 all 2021.1-2304.beta10 [4,854 kB]
Get:76 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mkl-devel-2021.1-beta10 amd64 2021.1-2304.beta10 [158 MB]
Get:77 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mkl-devel amd64 2021.1-2304.beta10 [1,698 B]
Get:78 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-mkl amd64 2021.1-2304.beta10 [1,862 B]
Err:79 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal amd64 2021.1-2300.beta10
Ign:80 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-common-2021.1-beta09 all 2021.1-2160.beta09
Err:81 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-2021.1-beta09 amd64 2021.1-2160.beta09
Err:82 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp amd64 2021.1-2160.beta09
Err:83 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-python amd64 2021.1-679.beta10
Ign:84 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-common-devel-2021.1-beta09 all 2021.1-2160.beta09
Err:85 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-devel-2021.1-beta09 amd64 2021.1-2160.beta09
Err:86 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-devel amd64 2021.1-2160.beta09
Ign:87 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-common-2021.1-beta09 all 2021.1-2173.beta09
Err:88 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-2021.1-beta09 amd64 2021.1-2173.beta09
Ign:89 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-common-devel-2021.1-beta09 all 2021.1-2173.beta09
Err:90 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-devel-2021.1-beta09 amd64 2021.1-2173.beta09
Err:91 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-devel amd64 2021.1-2173.beta09
Err:92 https://apt.repos.intel.com/oneapi all/main amd64 intel-basekit amd64 2021.1-2261.beta10
Err:18 https://apt.repos.intel.com/oneapi all/main amd64 intel-basekit-getting-started all 2021.1-2261.beta10
Err:55 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-debugger-eclipse-cfg all 10.0-2174.beta10
Err:64 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-common-2021.1-beta10 all 2021.1-2300.beta10
Err:66 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dal-common-devel-2021.1-beta10 all 2021.1-2300.beta10
Err:69 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-dpcpp-ct-eclipse-cfg all 2021.1-718.beta10
Err:80 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-common-2021.1-beta09 all 2021.1-2160.beta09
Err:84 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ipp-common-devel-2021.1-beta09 all 2021.1-2160.beta09
Err:87 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-common-2021.1-beta09 all 2021.1-2173.beta09
Err:89 https://apt.repos.intel.com/oneapi all/main amd64 intel-oneapi-ippcp-common-devel-2021.1-beta09 all 2021.1-2173.beta09
Fetched 1,365 MB in 52s (26.3 MB/s)
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-basekit-getting-started-2021.1-2261.beta10_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-vtune-2021.1-739.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ccl-2021.1-beta10-2021.1-1101.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-mpi-devel-2021.1-beta10-2021.1-2190.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-mpi-devel-2021.1-2190.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ccl-devel-2021.1-beta10-2021.1-1101.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ccl-devel-2021.1-1101.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-libdpstd-devel-2021.1-2496.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dpcpp-debugger-eclipse-cfg-10.0-2174.beta10_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dpcpp-debugger-10.0-beta10-10.0-2174.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dpcpp-debugger-10.0-2174.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-onevpl-2021.1-beta10-2021.1-664.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-onevpl-devel-2021.1-beta10-2021.1-664.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-onevpl-devel-2021.1-664.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dnnl-2021.1-2144.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dnnl-devel-2021.1-2144.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dal-common-2021.1-beta10-2021.1-2300.beta10_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dal-2021.1-beta10-2021.1-2300.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dal-common-devel-2021.1-beta10-2021.1-2300.beta10_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dal-devel-2021.1-beta10-2021.1-2300.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dal-devel-2021.1-2300.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dpcpp-ct-eclipse-cfg-2021.1-718.beta10_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dpcpp-ct-2021.1-beta10-2021.1-718.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dpcpp-ct-2021.1-718.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-advisor-2021.1-668.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-dal-2021.1-2300.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ipp-common-2021.1-beta09-2021.1-2160.beta09_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ipp-2021.1-beta09-2021.1-2160.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ipp-2021.1-2160.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-python-2021.1-679.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ipp-common-devel-2021.1-beta09-2021.1-2160.beta09_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ipp-devel-2021.1-beta09-2021.1-2160.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ipp-devel-2021.1-2160.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ippcp-common-2021.1-beta09-2021.1-2173.beta09_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ippcp-2021.1-beta09-2021.1-2173.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ippcp-common-devel-2021.1-beta09-2021.1-2173.beta09_all.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ippcp-devel-2021.1-beta09-2021.1-2173.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-oneapi-ippcp-devel-2021.1-2173.beta09_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
E: Failed to fetch https://apt.repos.intel.com/oneapi/pool/main/intel-basekit-2021.1-2261.beta10_amd64.deb 403 Forbidden [IP: 10.22.230.62 912]
GouthamK_Intel
We are forwarding this thread to the concerned internal team.
Goutham
jitendra42
Hi Goutham,
Any update on this issues?
Barbara_P_Intel
I have a few questions.
Are you trying to use the Docker environment provided by Intel?
Are you in a proxy environment?
Does "sudo apt-get update" work for you?
jitendra42
I am creating a new dockerfile from ubuntu:20.04.
Yes apt-get update is working.
I am behind proxy and providing proxy url via build args
I tried to build again today and exact same dockerfile and it worked. Not sure what fixed it.
Barbara_P_Intel
That's great news!
I'll go ahead and close this then.
