I think I have found a bug in Intel(R) oneAPI DPC++/C++ Compiler , Version 2021.2.0 Build 20210317. When compiling __cpuid, the following assembly is produced and not surprisingly it gives and exception:
xorl %edi, %edi
xorl %eax, %eax
xorl %ecx, %ecx
#APP
cpuid
#NO_APP
movl %eax, 48(%rbx)
movl %ebx, 52(%rbx)
movl %ecx, 56(%rbx)
movl %edx, 60(%rbx)
To reproduce the error copy the example from the following website (to Instructionset.cpp):
https://docs.microsoft.com/en-us/cpp/intrinsics/cpuid-cpuidex?view=msvc-160
compile it with: icx -mavx2 -EHsc Instructionset.cpp
Note that both -mavx2 and -EHsc flags are required to produce the error.
- Tags:
- C++ _cpuid
Hi Laszlo,
Please send us complete details of your environment where you are getting the error, we will try to reproduce it and will update you with the details.
Warm Regards,
Abhishek
I am using Win 10 Pro, Version 1909 (OSBuild 18363.1440). Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2021.2.0 Build 20210317
Do you need something else?
Hi Laszlo,
Thank you for the details.
We are able to reproduce the problem you are getting(only with -mavx2 flag) on the same mentioned environment, we are working on this internally and will update you with the details.
Thanks for reporting the issue.
Warm Regards,
Abhishek
Thank you for letting us know about the issue. It is escalated to the internal development team.
Thank you for your patience. The issue raised by you has been fixed in 2021.4 version. Please download and let us know if this resolves your issue.
Shanmukh.SS
