We learned that the new DPC compiler has better performance,So we wanted to try DPC。 However, we encountered some problems. The new compiler was more strict with syntax checking, resulting in many code compilation errors, and ICC had different compilation options than DPC; I don't know how to get the compiler to ignore these errors;
for example: ./pl_rx_pub/PUSCH/src/fde_sch_const.c:1919:117: error: constant expression evaluates to 50311 which cannot be narrowed to type 'Sshort' (aka 'short') [-Wc++11-narrowing] 0x7fff, 0x7fff, 0x7856, 0x6885, 0x58b0, 0x48e4, 0x392f, 0x299e, 0x1a3c, 0x0b18, 0xfc3c, 0xedb5, 0xdf8d, 0xd1d0, 0xc487, 0xb7be,
This error is just one of a number of grammar errors that would normally be ignored
Could you please provide the OS details and Intel one API DPC++ version you are using?
Could you also provide the sample reproducer code and the steps to reproduce the issue from our side?
Can we also have the complete error log/screenshot to understand better?
Meanwhile, you can refer to the below link for the compilation options in DPCPP
Thanks & Regards
Shivani
Thank you for your reply,my os version is centos7,and oneapi version is 2021.03;
My error code is as follows:
Sshort Gxxxx[20] = {0x7fff, 0x7fff, 0x7856, 0x6885, 0x58b0, 0x48e4, 0x392f, 0x299e, 0x1a3c, 0x0b18, 0xfc3c, 0xedb5, 0xdf8d, 0xd1d0, 0xc487, 0xb7be};
The error message is:
the 0xc487 is 50311,The compiler might think that this number is +50311, which cannot be represented by Sshort;
If I changed the code like this:
Sshort Gxxxx[20] = {(Sshort)0x7fff, (Sshort)0x7fff....
I might not get an error, but there's a lot of it, and I hope the compiler can ignore it
This code does not report an error in ICC;
Thanks for providing the requested details.
We can see that you are using CentOS 7 which is not listed under DPC++ supported OS. Please refer to the below system requirements page for more details.
Regarding the new compiler: DPCPP Compiler(Clang) is a stricter compiler than ICC and the errors(syntax errors) which you are facing are expected. Currently, there are no flags to suppress these errors and there is no way to avoid them.
We suggest you refine the code and try running it.
Please let us know if you face any further issues.
Thanks & Regards
Shivani
You can try -Wno-c++11-narrowing,
$ dpcpp foo.cpp -c
foo.cpp:4:17: error: constant expression evaluates to 50311 which cannot be narrowed to type 'short'
short a[2] = { 0xc487, 0xb7be};
foo.cpp:4:17: note: insert an explicit cast to silence this issue
static_cast<short>( )
foo.cpp:4:25: error: constant expression evaluates to 47038 which cannot be narrowed to type 'short'
foo.cpp:4:25: note: insert an explicit cast to silence this issue
2 errors generated.
$ dpcpp foo.cpp -Wno-c++11-narrowing
$ cat foo.cpp
#include<stdio.h>
int main () {
printf (" %d and %d \n", a[0], a[1]);
return 0;
Could you please try the workaround provided in the previous post by Viet_H_Intel and get back to us with an update? If you face any issues please let us know.
Thanks & Regards
Shivani
As I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards
Shivani
