Hi all
I used oneapi beta05 to run a program which is migrated from cuda.
But an error occur when I run the program which is generated by passed '-g' flag to dpcpp:
DIBlockByRefStruct on DICompositeType is no longer supported !610 = !DICompositeType(tag: DW_TAG_structure_type, name: "multi_ptr", scope: !148, file: !537, line: 23, flags: DIFlagReservedBit4, elements: !140) DIBlockByRefStruct on DICompositeType is no longer supported !1060 = !DICompositeType(tag: DW_TAG_structure_type, name: "opencl_event_t", file: !143, flags: DIFlagReservedBit4, elements: !140)
If '-g' is removed, there is no error.
How could I fix it?
Can you try updating your toolkit to beta-07, and update us if the error still persists?
Also, give us a small reproducer so that we can check if the problem is with your application or the toolkit.
Warm Regards,
Abhishek
Please Update us if still, you are facing the same issue. We have tried on our end but we haven't got this issue with the beta-07 release.
Thank you
Please post a new thread if you are having any issues.
Thank you
Topic Options
