Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
error "DIBlockByRefStruct on DICompositeType is no longer supported"
Jim
Hi all
I used oneapi beta05 to run a program which is migrated from cuda.
But an error occur when I run the program which is generated by passed '-g' flag to dpcpp:
DIBlockByRefStruct on DICompositeType is no longer supported !610 = !DICompositeType(tag: DW_TAG_structure_type, name: "multi_ptr", scope: !148, file: !537, line: 23, flags: DIFlagReservedBit4, elements: !140) DIBlockByRefStruct on DICompositeType is no longer supported !1060 = !DICompositeType(tag: DW_TAG_structure_type, name: "opencl_event_t", file: !143, flags: DIFlagReservedBit4, elements: !140)
If '-g' is removed, there is no error.
How could I fix it?
AbhishekD_Intel
Can you try updating your toolkit to beta-07, and update us if the error still persists?
Also, give us a small reproducer so that we can check if the problem is with your application or the toolkit.
Warm Regards,
Abhishek
AbhishekD_Intel
Please Update us if still, you are facing the same issue. We have tried on our end but we haven't got this issue with the beta-07 release.
Thank you
AbhishekD_Intel
Please post a new thread if you are having any issues.
Thank you
