I get an issue when i run the hello_world examples.
The enviroment is ok, and "aocl program acl0 hello_world.aocx" have done before i run the main .
The issue as follows:
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1
Querying device for info:
CL_DEVICE_NAME = c5gt : Cyclone V HPC Reference Platform
CL_DEVICE_VENDOR = Terasic
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1
CL_DRIVER_VERSION = 17.1
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 1073741824
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 268435456
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Using AOCX: /opt/module/intelFPGA/17.1/hld/board/tsp/tests/spark_JNI_FPGA_HelloWorld/bin/hello_world.aocx
MMD INFO : [acl0] failed to program the device through CvP.
MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1""
mmd program_device: Board reprogram failed
Kernel initialization is complete.
Launching the kernel...
MMD FATAL: acl_pcie.cpp:62: can't find handle -1 -- aborting
Reprogramming device [0] with handle 1
sh: quartus_pgm: 未找到命令
java: acl_pcie.cpp:62: ACL_PCIE_DEVICE* get_pcie_device(int): Assertion `0' failed.
Above is all logs .
I don't think the red logs should appear at all.
Because I have executed "aocl program acl0 hello_world.aocx" this command in advance.
So it might be that the pcie issue? or jtag issue? or reconfiguration issue?
Why do programs need to reconfigure and recompile?
#include "HelloWorld.h"
#include <assert.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <cstring>
#include "CL/opencl.h"
#include "AOCLUtils/aocl_utils.h"
using namespace aocl_utils;
#define STRING_BUFFER_LEN 1024
// Runtime constants
// Used to define the work set over which this kernel will execute.
static const size_t work_group_size = 8; // 8 threads in the demo workgroup
// Defines kernel argument value, which is the workitem ID that will
// execute a printf call
static const int thread_id_to_output = 2;
// OpenCL runtime configuration
static cl_platform_id platform = NULL;
static cl_device_id device = NULL;
static cl_context context = NULL;
static cl_command_queue queue = NULL;
static cl_kernel kernel = NULL;
static cl_program program = NULL;
// Function prototypes
bool init();
void cleanup();
static void device_info_ulong(cl_device_id device, cl_device_info param, const char* name);
static void device_info_uint(cl_device_id device, cl_device_info param, const char* name);
static void device_info_bool(cl_device_id device, cl_device_info param, const char* name);
static void device_info_string(cl_device_id device, cl_device_info param, const char* name);
static void display_device_info(cl_device_id device);
// main points
JNIEXPORT void JNICALL Java_HelloWorld_helloWorld
(JNIEnv* env, jobject jobj) {
cl_int status;
if (!init()) {
return;
// Set the kernel argument (argument 0)
status = clSetKernelArg(kernel, 0, sizeof(cl_int), (void*)&thread_id_to_output);
checkError(status, "Failed to set kernel arg 0");
printf("\nKernel initialization is complete.\n");
printf("Launching the kernel...\n\n");
// Configure work set over which the kernel will execute
size_t wgSize[3] = { work_group_size, 1, 1 };
size_t gSize[3] = { work_group_size, 1, 1 };
// Launch the kernel
status = clEnqueueNDRangeKernel(queue, kernel, 1, NULL, gSize, wgSize, 0, NULL, NULL);
checkError(status, "Failed to launch kernel");
// Wait for command queue to complete pending events
status = clFinish(queue);
checkError(status, "Failed to finish");
printf("\nKernel execution is complete.\n");
// Free the resources allocated
cleanup();
return;
/////// HELPER FUNCTIONS ///////
bool init() {
cl_int status;
if (!setCwdToExeDir()) {
return false;
// Get the OpenCL platform.
platform = findPlatform("Intel(R) FPGA");
if (platform == NULL) {
printf("ERROR: Unable to find Intel(R) FPGA OpenCL platform.\n");
return false;
// User-visible output - Platform information
char char_buffer[STRING_BUFFER_LEN];
printf("Querying platform for info:\n");
printf("==========================\n");
clGetPlatformInfo(platform, CL_PLATFORM_NAME, STRING_BUFFER_LEN, char_buffer, NULL);
printf("%-40s = %s\n", "CL_PLATFORM_NAME", char_buffer);
clGetPlatformInfo(platform, CL_PLATFORM_VENDOR, STRING_BUFFER_LEN, char_buffer, NULL);
printf("%-40s = %s\n", "CL_PLATFORM_VENDOR ", char_buffer);
clGetPlatformInfo(platform, CL_PLATFORM_VERSION, STRING_BUFFER_LEN, char_buffer, NULL);
printf("%-40s = %s\n\n", "CL_PLATFORM_VERSION ", char_buffer);
// Query the available OpenCL devices.
scoped_array<cl_device_id> devices;
cl_uint num_devices;
devices.reset(getDevices(platform, CL_DEVICE_TYPE_ALL, &num_devices));
// We'll just use the first device.
device = devices[0];
// Display some device information.
display_device_info(device);
// Create the context.
context = clCreateContext(NULL, 1, &device, &oclContextCallback, NULL, &status);
checkError(status, "Failed to create context");
// Create the command queue.
queue = clCreateCommandQueue(context, device, CL_QUEUE_PROFILING_ENABLE, &status);
checkError(status, "Failed to create command queue");
// Create the program.
std::string binary_file = getBoardBinaryFile("/opt/module/intelFPGA/17.1/hld/board/tsp/tests/spark_JNI_FPGA_HelloWorld/bin/hello_world", device);
printf("Using AOCX: %s\n", binary_file.c_str());
program = createProgramFromBinary(context, binary_file.c_str(), &device, 1);
// Build the program that was just created.
status = clBuildProgram(program, 0, NULL, "", NULL, NULL);
checkError(status, "Failed to build program");
// Create the kernel - name passed in here must match kernel name in the
// original CL file, that was compiled into an AOCX file using the AOC tool
const char* kernel_name = "hello_world"; // Kernel name, as defined in the CL file
kernel = clCreateKernel(program, kernel_name, &status);
checkError(status, "Failed to create kernel");
return true;
// Free the resources allocated during initialization
void cleanup() {
if (kernel) {
clReleaseKernel(kernel);
if (program) {
clReleaseProgram(program);
if (queue) {
clReleaseCommandQueue(queue);
if (context) {
clReleaseContext(context);
// Helper functions to display parameters returned by OpenCL queries
static void device_info_ulong(cl_device_id device, cl_device_info param, const char* name) {
cl_ulong a;
clGetDeviceInfo(device, param, sizeof(cl_ulong), &a, NULL);
printf("%-40s = %lu\n", name, a);
static void device_info_uint(cl_device_id device, cl_device_info param, const char* name) {
cl_uint a;
clGetDeviceInfo(device, param, sizeof(cl_uint), &a, NULL);
printf("%-40s = %u\n", name, a);
static void device_info_bool(cl_device_id device, cl_device_info param, const char* name) {
cl_bool a;
clGetDeviceInfo(device, param, sizeof(cl_bool), &a, NULL);
printf("%-40s = %s\n", name, (a ? "true" : "false"));
static void device_info_string(cl_device_id device, cl_device_info param, const char* name) {
char a[STRING_BUFFER_LEN];
clGetDeviceInfo(device, param, STRING_BUFFER_LEN, &a, NULL);
printf("%-40s = %s\n", name, a);
// Query and display OpenCL information on device and runtime environment
static void display_device_info(cl_device_id device) {
printf("Querying device for info:\n");
printf("========================\n");
device_info_string(device, CL_DEVICE_NAME, "CL_DEVICE_NAME");
device_info_string(device, CL_DEVICE_VENDOR, "CL_DEVICE_VENDOR");
device_info_uint(device, CL_DEVICE_VENDOR_ID, "CL_DEVICE_VENDOR_ID");
device_info_string(device, CL_DEVICE_VERSION, "CL_DEVICE_VERSION");
device_info_string(device, CL_DRIVER_VERSION, "CL_DRIVER_VERSION");
device_info_uint(device, CL_DEVICE_ADDRESS_BITS, "CL_DEVICE_ADDRESS_BITS");
device_info_bool(device, CL_DEVICE_AVAILABLE, "CL_DEVICE_AVAILABLE");
device_info_bool(device, CL_DEVICE_ENDIAN_LITTLE, "CL_DEVICE_ENDIAN_LITTLE");
device_info_ulong(device, CL_DEVICE_GLOBAL_MEM_CACHE_SIZE, "CL_DEVICE_GLOBAL_MEM_CACHE_SIZE");
device_info_ulong(device, CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE, "CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE");
device_info_ulong(device, CL_DEVICE_GLOBAL_MEM_SIZE, "CL_DEVICE_GLOBAL_MEM_SIZE");
device_info_bool(device, CL_DEVICE_IMAGE_SUPPORT, "CL_DEVICE_IMAGE_SUPPORT");
device_info_ulong(device, CL_DEVICE_LOCAL_MEM_SIZE, "CL_DEVICE_LOCAL_MEM_SIZE");
device_info_ulong(device, CL_DEVICE_MAX_CLOCK_FREQUENCY, "CL_DEVICE_MAX_CLOCK_FREQUENCY");
device_info_ulong(device, CL_DEVICE_MAX_COMPUTE_UNITS, "CL_DEVICE_MAX_COMPUTE_UNITS");
device_info_ulong(device, CL_DEVICE_MAX_CONSTANT_ARGS, "CL_DEVICE_MAX_CONSTANT_ARGS");
device_info_ulong(device, CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE, "CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE");
device_info_uint(device, CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS, "CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS");
device_info_uint(device, CL_DEVICE_MEM_BASE_ADDR_ALIGN, "CL_DEVICE_MEM_BASE_ADDR_ALIGN");
device_info_uint(device, CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE, "CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE");
device_info_uint(device, CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR, "CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR");
device_info_uint(device, CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT, "CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT");
device_info_uint(device, CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT, "CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT");
device_info_uint(device, CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG, "CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG");
device_info_uint(device, CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT, "CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT");
device_info_uint(device, CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE, "CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE");
cl_command_queue_properties ccp;
clGetDeviceInfo(device, CL_DEVICE_QUEUE_PROPERTIES, sizeof(cl_command_queue_properties), &ccp, NULL);
printf("%-40s = %s\n", "Command queue out of order? ", ((ccp & CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE) ? "true" : "false"));
printf("%-40s = %s\n", "Command queue profiling enabled? ", ((ccp & CL_QUEUE_PROFILING_ENABLE) ? "true" : "false"));
