Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
install failed
DeliangMa
05/29/2022 10:44:04:664 : 2528 : MESSAGE : C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe is run with arguments: --log-dir C:/Users/MaDeliang/AppData/Local/Temp/intel_oneapi_installer/2022.05.29.10.43.50.840 --product-id intel.oneapi.win.basekit.product --product-ver 2022.2.0-252 --package-path C:\Users\MaDeliang\AppData\Local\Temp\w_BaseKit_p_2022.2.0.252_2022-05-29_10-43-50\packages
05/29/2022 10:44:04:664 : 2528 : MESSAGE : Installer is started in GUI mode
05/29/2022 10:44:04:664 : 2528 : MESSAGE : Installer executable location is C:\Program Files (x86)\Intel\oneAPI\Installer\installer.exe, version is 4.1.1.0-291
05/29/2022 10:44:04:664 : 2528 : MESSAGE : Package manager executable location is C:\Program Files (x86)\Intel\PackageManager\1.0\packagemanager.exe, version is 4.1.5-274
05/29/2022 10:44:04:665 : 2528 : MESSAGE : Product is set to intel.oneapi.win.basekit.product,v=2022.2.0-252. Mode is set to install.
05/29/2022 10:44:05:561 : 7288 : MESSAGE : PreRequisite for other install successfully checked
05/29/2022 10:44:05:569 : 7288 : MESSAGE : PreRequisite for other Intel install successfully checked
05/29/2022 10:44:05:574 : 7288 : MESSAGE : All checks for preRequisite for supported operation system are passed
05/29/2022 10:44:05:884 : 7288 : MESSAGE : PreRequisite for admin rights successfully checked
05/29/2022 10:44:05:885 : 7288 : MESSAGE : PreRequisite for temporary folder successfully checked
05/29/2022 10:44:05:885 : 7288 : MESSAGE : PreRequisite for host architecture successfully checked
05/29/2022 10:44:48:770 : 11596 : MESSAGE : Changed installation directory from 'C:\Program Files (x86)\Intel\oneAPI' to 'D:\intel'.
05/29/2022 10:44:59:375 : 11596 : MESSAGE : PreRequisite for Instance Msi successfully checked
05/29/2022 10:45:02:568 : 11596 : MESSAGE : PreRequisite for free disk space passed
05/29/2022 10:45:02:571 : 11596 : MESSAGE : PreRequisite for permissions passed
05/29/2022 10:45:02:571 : 11596 : MESSAGE : PreRequisite for other install successfully checked
05/29/2022 10:45:02:571 : 11596 : MESSAGE : PreRequisite for other Intel install successfully checked
05/29/2022 10:45:02:602 : 11596 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.2022] passed
05/29/2022 10:45:02:602 : 11596 : MESSAGE : PreRequisite for Visual Studio running with id = [visualStudioRunning.OtherUsers] passed
05/29/2022 10:45:02:629 : 2528 : MESSAGE : ISIP consent status is 'Yes'
05/29/2022 10:45:02:630 : 2528 : MESSAGE : Product installation directory is D:\intel
05/29/2022 10:45:02:630 : 2528 : MESSAGE : Product download size required: 1055660714 bytes
05/29/2022 10:45:02:630 : 2528 : MESSAGE : Product installation size required: 7098950075 bytes
05/29/2022 10:45:02:630 : 2528 : MESSAGE : Product will be (un)integrated with the following IDEs:
05/29/2022 10:45:02:630 : 2528 : MESSAGE : Microsoft Visual Studio* 2022
05/29/2022 10:45:02:631 : 2528 : MESSAGE : End of IDE list.
05/29/2022 10:45:02:649 : 11596 : MESSAGE : Graph State Dump.
intel.oneapi.win.basekit.product,v=2022.2.0-252, Enabled, Selected, Not Installed
intel.oneapi.win.basekit.getting_started,v=2022.2.0-252, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.vars,v=2022.1.0-157, Enabled, Selected, Not Installed
intel.oneapi.win.oneapi-common.licensing,v=2022.1.0-157, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_ct.common,v=2022.1.0-183, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2017,v=2022.1.0-183, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2019,v=2022.1.0-183, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_ct.vs2022,v=2022.1.0-183, Enabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities,v=2021.6.0-989, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.common,v=2021.6.0-989, Enabled, Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2017,v=2021.6.0-989, Disabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2019,v=2021.6.0-989, Disabled, Not Selected, Not Installed
intel.oneapi.win.dev-utilities.vs2022,v=2021.6.0-989, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger,v=2021.6.0-188, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2017,v=2021.6.0-188, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2017,v=2021.6.0-188, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2019,v=2021.6.0-188, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2019,v=2021.6.0-188, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2021.6.0-188, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2021.6.0-188, Enabled, Selected, Not Installed
intel.oneapi.win.dpl,v=2021.7.0-614, Enabled, Not Selected, Not Installed
intel.oneapi.win.condaindex,v=2022.1.0-141, Enabled, Selected, Not Installed
intel.oneapi.win.tbb.devel,v=2021.6.0-834, Enabled, Not Selected, Not Installed
intel.oneapi.win.tbb.runtime,v=2021.6.0-834, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2022.1.0-256, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.vcperflib_bt_vs2022,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler,v=2022.1.0-3787, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-dpcpp-common,v=2022.1.0-3787, Enabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common,v=2022.1.0-3787, Enabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common-runtime,v=2022.1.0-3787, Enabled, Selected, Not Installed
intel.oneapi.win.openmp,v=2022.1.0-3787, Enabled, Selected, Not Installed
intel.oneapi.win.cpp-base-pro-common-runtime,v=2022.1.0-3787, Enabled, Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2021_VS150.vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS150.vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2021_VS160.vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS160.vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_shared.vs2022,v=2022.1.0-256, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.vs2022,v=2022.1.0-256, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide_unique2022_VS170.vs2022,v=2022.1.0-256, Enabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dpcpp-compiler.ide.bt_vs2022,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique192_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.compilers-common.ide.common,v=2022.1.0-256, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique193_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique192_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_llvm_unique193_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_vsix_llvm_vs2022,v=2022.1.0-256, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_vsix_llvm_vs2022,v=2022.1.0-256, Enabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_193_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2017,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_193_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2019,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.unique_bt_llvm_vs2022,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.cpp-compiler.ide.shared_bt_llvm_vs2022,v=2022.1.0-256, Disabled, Not Selected, Not Installed
intel.oneapi.win.dal.devel,v=2021.6.0-874, Enabled, Not Selected, Not Installed
intel.oneapi.win.dal.runtime,v=2021.6.0-874, Enabled, Not Selected, Not Installed
intel.oneapi.win.vpl,v=2022.1.0-151, Enabled, Not Selected, Not Installed
intel.oneapi.win.ipp.devel,v=2021.6.0-606, Enabled, Not Selected, Not Installed
intel.oneapi.win.ipp.runtime,v=2021.6.0-606, Enabled, Not Selected, Not Installed
intel.oneapi.win.ippcp,v=2021.6.0-515, Enabled, Not Selected, Not Installed
intel.oneapi.win.mkl.devel,v=2022.1.0-192, Enabled, Selected, Not Installed
intel.oneapi.win.mkl.runtime,v=2022.1.0-192, Enabled, Selected, Not Installed
intel.oneapi.win.advisor,v=2022.1.0-153, Enabled, Not Selected, Not Installed
intel.oneapi.win.advisor.vsix,v=2022.1.0-153, Enabled, Not Selected, Not Installed
intel.oneapi.win.advisor.vs2017,v=2022.1.0-153, Disabled, Not Selected, Not Installed
intel.oneapi.win.advisor.vs2019,v=2022.1.0-153, Disabled, Not Selected, Not Installed
intel.oneapi.win.python3,v=2022.1.0-212, Enabled, Not Selected, Not Installed
intel.oneapi.win.dal.daal4py,v=2021.6.0-874, Enabled, Not Selected, Not Installed
intel.oneapi.win.dal.skleranex,v=2021.6.0-874, Enabled, Not Selected, Not Installed
intel.oneapi.win.mpi.runtime,v=2021.6.0-546, Enabled, Not Selected, Not Installed
intel.oneapi.win.vtune,v=2022.2.0-166, Enabled, Not Selected, Not Installed
intel.oneapi.win.vtune.vsix,v=2022.2.0-166, Enabled, Not Selected, Not Installed
intel.oneapi.win.vtune.vs2017,v=2022.2.0-166, Disabled, Not Selected, Not Installed
intel.oneapi.win.vtune.vs2019,v=2022.2.0-166, Disabled, Not Selected, Not Installed
intel.oneapi.win.vtune.vs2022,v=2022.2.0-166, Enabled, Not Selected, Not Installed
intel.oneapi.win.dnnl,v=2022.1.0-88, Enabled, Not Selected, Not Installed
05/29/2022 10:45:02:652 : 11596 : MESSAGE : Operations dump.
Updating package state...
Preparing installation...
Protecting installation location...
Finalizing removal. It may take up to 5 minutes...
Install intel.oneapi.win.basekit.getting_started,v=2022.2.0-252
Install intel.oneapi.win.oneapi-common.vars,v=2022.1.0-157
Install intel.oneapi.win.oneapi-common.licensing,v=2022.1.0-157
Install intel.oneapi.win.dev-utilities.common,v=2021.6.0-989
Install intel.oneapi.win.dev-utilities.vs2022,v=2021.6.0-989
Install intel.oneapi.win.dev-utilities,v=2021.6.0-989
Install intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2021.6.0-188
Install intel.oneapi.win.dpcpp_debugger.vsmi.vs2022,v=2021.6.0-188
Install intel.oneapi.win.dpcpp_debugger,v=2021.6.0-188
Install intel.oneapi.win.condaindex,v=2022.1.0-141
Install intel.oneapi.win.openmp,v=2022.1.0-3787
Install intel.oneapi.win.compilers-common-runtime,v=2022.1.0-3787
Install intel.oneapi.win.cpp-base-pro-common-runtime,v=2022.1.0-3787
Install intel.oneapi.win.tbb.runtime,v=2021.6.0-834
Install intel.oneapi.win.mkl.runtime,v=2022.1.0-192
Install intel.oneapi.win.cpp-compiler.ide.vcperflib_vsix_vs2022,v=2022.1.0-256
Install intel.oneapi.win.mkl.devel,v=2022.1.0-192
Install intel.oneapi.win.basekit.product,v=2022.2.0-252
Finalizing. It may take up to 10 minutes or more to integrate with your system, please do not interrupt the install process...
05/29/2022 10:45:03:258 : 11596 : MESSAGE : Start install/modify sequence execution.
05/29/2022 10:45:03:273 : 11596 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1653792302649131'.
05/29/2022 10:45:03:273 : 11596 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1653792302649131' execution is finished with status Success.
05/29/2022 10:45:03:273 : 11596 : MESSAGE : Starting execution of operation 'prepare.operation.intel.sessionmanifest.1653792302649131'.
05/29/2022 10:45:03:273 : 11596 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1653792302649131' execution is finished with status Success.
05/29/2022 10:45:03:273 : 11596 : MESSAGE : Starting execution of operation 'protect.operation.intel.sessionmanifest.1653792302649131'.
05/29/2022 10:45:03:525 : 11596 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1653792302649131' execution is finished with status Success.
05/29/2022 10:45:03:525 : 11596 : MESSAGE : Starting execution of operation 'complete.operation.intel.sessionmanifest.1653792302649133'.
05/29/2022 10:45:03:525 : 11596 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1653792302649133' execution is finished with status Success.
05/29/2022 10:46:34:183 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.basekit.getting_started,v=2022.2.0-252'.
05/29/2022 10:46:34:294 : 11596 : MESSAGE : Operation 'intel.oneapi.win.basekit.getting_started,v=2022.2.0-252' execution is finished with status Success.
05/29/2022 10:46:34:294 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.vars,v=2022.1.0-157'.
05/29/2022 10:46:36:064 : 11596 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2022.1.0-157' execution is finished with status Success.
05/29/2022 10:46:36:064 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.oneapi-common.licensing,v=2022.1.0-157'.
05/29/2022 10:46:36:456 : 11596 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2022.1.0-157' execution is finished with status Success.
05/29/2022 10:46:36:456 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities.common,v=2021.6.0-989'.
05/29/2022 10:46:37:277 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.common,v=2021.6.0-989' execution is finished with status Success.
05/29/2022 10:46:37:277 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.6.0-989'.
05/29/2022 10:46:37:553 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.6.0-989' execution is finished with status Success.
05/29/2022 10:46:37:553 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dev-utilities,v=2021.6.0-989'.
05/29/2022 10:46:37:654 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities,v=2021.6.0-989' execution is finished with status Success.
05/29/2022 10:46:39:906 : 11596 : MESSAGE : Starting execution of operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2021.6.0-188'.
05/29/2022 10:46:41:019 : 11596 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.dpcpp_debugger.fee.vs2022, name: Intel® Distribution for GDB*, version: 2021.6.0-188.
Error: Sequence execution failed.
05/29/2022 10:46:41:019 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dpcpp_debugger.fee.vs2022,v=2021.6.0-188' execution is finished with status Fail.
05/29/2022 10:46:41:019 : 11596 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dev-utilities,v=2021.6.0-989'.
05/29/2022 10:46:41:227 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities,v=2021.6.0-989' rollback is finished with status Success.
05/29/2022 10:46:41:227 : 11596 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.6.0-989'.
05/29/2022 10:46:41:492 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.vs2022,v=2021.6.0-989' rollback is finished with status Success.
05/29/2022 10:46:41:492 : 11596 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.dev-utilities.common,v=2021.6.0-989'.
05/29/2022 10:46:42:169 : 11596 : MESSAGE : Operation 'intel.oneapi.win.dev-utilities.common,v=2021.6.0-989' rollback is finished with status Success.
05/29/2022 10:46:42:169 : 11596 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.licensing,v=2022.1.0-157'.
05/29/2022 10:46:42:804 : 11596 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.licensing,v=2022.1.0-157' rollback is finished with status Success.
05/29/2022 10:46:42:804 : 11596 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.oneapi-common.vars,v=2022.1.0-157'.
05/29/2022 10:46:44:664 : 11596 : MESSAGE : Operation 'intel.oneapi.win.oneapi-common.vars,v=2022.1.0-157' rollback is finished with status Success.
05/29/2022 10:46:44:664 : 11596 : MESSAGE : Starting rollback of operation 'intel.oneapi.win.basekit.getting_started,v=2022.2.0-252'.
05/29/2022 10:46:44:932 : 11596 : MESSAGE : Operation 'intel.oneapi.win.basekit.getting_started,v=2022.2.0-252' rollback is finished with status Success.
05/29/2022 10:46:44:932 : 11596 : MESSAGE : Starting rollback of operation 'complete.operation.intel.sessionmanifest.1653792302649133'.
05/29/2022 10:46:45:077 : 11596 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1653792302649133' rollback is finished with status Success.
05/29/2022 10:46:45:077 : 11596 : MESSAGE : Starting rollback of operation 'protect.operation.intel.sessionmanifest.1653792302649131'.
05/29/2022 10:46:45:077 : 11596 : MESSAGE : Operation 'protect.operation.intel.sessionmanifest.1653792302649131' rollback is finished with status Success.
05/29/2022 10:46:45:077 : 11596 : MESSAGE : Starting rollback of operation 'prepare.operation.intel.sessionmanifest.1653792302649131'.
05/29/2022 10:46:45:077 : 11596 : MESSAGE : Operation 'prepare.operation.intel.sessionmanifest.1653792302649131' rollback is finished with status Success.
05/29/2022 10:46:45:077 : 11596 : MESSAGE : Starting rollback of operation 'update_state.operation.intel.sessionmanifest.1653792302649131'.
05/29/2022 10:46:45:078 : 11596 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1653792302649131' rollback is finished with status Success.
05/29/2022 10:46:45:078 : 11596 : ERROR : Install sequence execution status: Rollback
05/29/2022 10:46:45:110 : 2528 : MESSAGE : ----------------------------------------------------------------------------------------------------
05/29/2022 10:46:45:110 : 2528 : MESSAGE : Anonymous statistics fields:
05/29/2022 10:46:45:110 : 2528 : MESSAGE : EventId = 'install-min'
05/29/2022 10:46:45:110 : 2528 : MESSAGE : EventTime = ''
05/29/2022 10:46:45:110 : 2528 : MESSAGE : Id = 'intel.oneapi.win.basekit.product,v=2022.2.0-252'
05/29/2022 10:46:45:110 : 2528 : MESSAGE : Message = '{ \"product_name\":\"[Windows] Intel® oneAPI Base Toolkit 2022.2\", \"lic_type\":\"\", \"support_code\":\"\", \"install_status\":\"4355\", \"product_tag\":\"\" }'
05/29/2022 10:46:45:110 : 2528 : MESSAGE : ProductId = '[Windows] Intel® oneAPI Base Toolkit 2022.2'
DenAndrew
Could you please share all logs of the failed install try (in zipped archive) from %temp%\intel_oneapi_installer.
Because I need to check logs exactly of intel.oneapi.win.dpcpp_debugger.fee.vs2022 module.
