Intel® oneAPI Base Toolkit
Support for the core tools and libraries within the base toolkit that are used to build and deploy high-performance data-centric applications.
419 Discussions
intrl S2400SC 主板因该安装那种磁盘管理驱动与RAID驱动,磁盘里着12T为什么分不了盘,也用不了
AMI1314
Labels (2)
RabiyaSK_Intel
Thanks for posting your question in the Intel Community Forums.
This is an English-only forum. I translated your question via Intel Secure Translator which generated the following text:
"The intrl S2400SC motherboard should install the disk management driver and RAID drive, why can't the disk be separated from the 12T disk, and it can't be used"
Does this reflect your question correctly so that we could redirect this issue to the right forum for better assistance?
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Shaik Rabiya
RabiyaSK_Intel
We have not heard back from you. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Shaik Rabiya
